Fab Four JL full tube door problems?
runeglfbrg
Carpentersville IL
2018 Jeep JL Rubicon Unlimited
Plumbing, HVAC, Electrical
Anyone else have any issues with the full Fab Four tube doors on a JL? I just got them this week. Glad I decided to put them together even though its still freezing cold. Even with this spacer they give you it hits the frame and doesn’t latch. I wont hear from them until Monday most likely so just seeing if anyone else has these and they work or the same problem?
Platinum7990
Zeb
Delaware
2020 Rubicon Unlimited Diesel & 2018 Jeep Grand Cherokee High Altitude
Cybersecurity
Hey were you able to fix this? I just got mine and I haven’t put it together yet but just checking up on this if I run into the same issues
Platinum7990
Zeb
Delaware
Cybersecurity
Hey sorry I got my doors and am running into the same issues. Can you tell me if you were able to fix it ?
j_anthony2000
Jason
Rogers, Arkansas
‘18 Jeep Wrangler JLU
I have the half doors and have had several conversations with Fab Fours regarding the design and the installation issue. Although they are super nice, I have stressed my concern to them and am still in the process of sending in photos of these issues. They will tell you that you should be adjusting the striker latch / plate for it to latch correctly. I didn't really like this answer because it could have been worked into the latch design. I had to use completely different bolts and spacers to allow the door to latch further away from the door frame so that door wouldn't hit the paint. Facing the drivers door, it's the lower right corner that would hit first and that dictates the amount of additional spacing needed for the latch position. A few tips: Fab Fours are recommending on their website JK mirrors (from Quadratec) to be mounted to their door / mirror bracket. https://www.quadratec.com/products/13111_0333_14.htm
You also will need to use the JK door hinge pin nuts. The JL hinge pin nuts are too long. The latch they use on their doors is a prefab latch designed from the JK specs. I just wish the install was a bit easier and for the cost of these doors, it should fit perfectly, which is does not.
Fab Fours stated to send them install photos to [email protected] and they will assist in figuring out a solution. Maybe if we flood them with install issues, they will rework the latch design.
JTopsUSA
