Extending the spare tire bump stops
RubiRob
Rob
Hampshire, IL
Mojave
Iwantfullauto
Louisiana
2018 Jeep Wrangler Unlimited Sport
I used the chair leg rubber tips you can buy at lows and it worked great.
WAOLIFE
Adrian & Josie
So Cal
2019 JLUM - 3.6L - Sky Touch & 2015 WK2O - 3.6L - IG: @wa0life
Fiddler of Parts
Seemed fairly straight forward to me.
HOOKEM93
Prosper, TX
2019 Jeep Wrangler JL Unlimited Sport Altitude
The Daystar stops in this link are either exactly what come with the Mopar reinforced carrier, or very close. All you need is something to keep the wheel from bouncing.
I'm guessing that these will fit a JL as well? Everything i can find with this product says it fits JK models. Thanks.
Sting_NC_USA
Greensboro, NC
2018 Jeep Wrangler JL Unlimited Rubicon
I ended up buying them and the plug part that screws into the back of the Jeep were too big. Had to return them. I'd stick with the black PVC pipe option, using pvc tubing that fits inside the stock bump stop. That's really the best option of all shared above.
Spdu4ia
Travis
2020 2dr Rubi
Just adding this to the list of possibilities. I took an old grip from a motorcycle and cut it in half used one on each side. Slid right into the stock bumper and works great
Bee-Rad
Austin, TX
2019 JL Sport
I used a rubber PVC coupler from Home Depot. Just took the hose clamps off. Measured and used a razor blade to cut to right size. I then zip tied it to the OEM bump stop.
Jeep Wrangler JL Extending the spare tire bump stops A9E587D3-F78D-455D-B5A9-BAAF9BD41AE3
Thanks for this idea! I used the 1 1/2" coupler and it slipped right over the OEM bump stop snugly. Just cut to length with razor blade.
BuffaloBill
WI
2018 Wrangler, 2014 Ram 1500 EcoDiesel 2020 JLUR Ecodiesel
Lots of ways to lengthen those as others said.
Just for reference, I have 315/70/17 KO2 on an 8.5” width wheel with +25mm offset, and found the factory tire bumpers to be the perfect length.
Nomoracin
Virginia
JLU Rubicon
I just put 35s on yesterday and ordered Energy Suspension Spare Tire Bumper, but in the meantime, I stuffed a raquetball ball in there and it’s working great. Haha
