cgpratt
- tim
- May 3, 2018
- buffalo ny
- 07 jk sahara, 18 sport s jl
Here is what they look like. Took 5 minutes and I had coupon !!
I really wanted those but I think they're only 4.5" long. Not enough for 3.5BS (just fyi for the more offset wheel folks)
I'm guessing that these will fit a JL as well? Everything i can find with this product says it fits JK models. Thanks.The Daystar stops in this link are either exactly what come with the Mopar reinforced carrier, or very close. All you need is something to keep the wheel from bouncing.
I ended up buying them and the plug part that screws into the back of the Jeep were too big. Had to return them. I'd stick with the black PVC pipe option, using pvc tubing that fits inside the stock bump stop. That's really the best option of all shared above.I'm guessing that these will fit a JL as well? Everything i can find with this product says it fits JK models. Thanks.
Thanks for this idea! I used the 1 1/2" coupler and it slipped right over the OEM bump stop snugly. Just cut to length with razor blade.I used a rubber PVC coupler from Home Depot. Just took the hose clamps off. Measured and used a razor blade to cut to right size. I then zip tied it to the OEM bump stop.
