Experience with Falcon 3.3 shocks on 2.5 RK lift
Gsmith317
Gabe
Pennsylvania
2018 Jeep Sahara Unlimited
I am debating on purchasing the falcon 3.3 shocks for my daily driver. I do off-road occasionally, so wondering if these are worth the investment. Any reviews would be appreciated! Do I need the 3.3 vs 2.1?
mgroeger
Hurricane, UT
2021 JLUR 2.0T, 1991 YJ rock crawler
My wife and I both run the 3.1 Falcon shocks with the 3.5" ST3 Teraflex lift and like it. The 3.1 and 3.3 are the same shock, the 3.3 is $400 more because it allows you the ability to adjust the stiffness of the shock. I'm told you can really dial those shocks in to your liking in terms of how soft or firm of a ride you want. I can tell you the 3.1 shocks are dialed in at the middle of the road for all around on and off road use and perform well. The ones on my Jeep have been wheeled very hard on many trails including the Rubicon and have done very well and still ride nice. The 2.1 shock is a single reservoir where the 3.1 and 3.3 are piggy back shocks and have better performance.
If money is not a major issue I'd skip the 2.1 shocks and go for the 3.1 or 3.3. Better to grow into the shock then realize you're growing out of one :)
Therby
Taylor
Ontario, Canada
2018 JL sport 2dr
another question for you. Im looking at the 2.1 for my jeep. Getting rid of the aev 5100s as I’ve swapped springs to the mopar 2” (liner spring and soft)
what do you think. I know the shock is “firmer” but with my soft springs..
thoughts?
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
I think the 3.1 SP2 is a good value because you can sort of dial it in between soft and stiff by rotating the shaft. And I think once dialed in I won’t need to touch it, it will always be on soft because of how stiff the Falcon shocks are.
mgroeger
Hurricane, UT
Hmmmm... are you sure about that? I thought that was only on the 3.3, the 3.3 has a dial AND you can rotate the shaft as well. I'm going to reach out to Teraflex adn ask them.
EDIT: We have the 3.1 Series3 Type1
mgroeger
Hurricane, UT
thoughts?
@mic.rempel is running those shocks with Teraflex springs and can comment.
Arterius2
Jerry
Vancouver, BC
