JP29
Wanted to chime in as I finally had the time and tools to get my Exact Center unit installed. I went with the 140 lb unit to future proof any lifting or bigger tires that I might add. I used the factory location bracket provided. Install was really pretty smooth, although I did have to undo the track bar at one end to get access to the two top bolts of the axle bracket (plus side, I know the track bar is good and tight now). Initially was pulling to the right a bit, but I got it dialed in to track dead straight after a few tries. Only other issue I ran into was needing more washers for the tire side bracket - the three supplied didn't quite take up the slop and at first I was crushing the bracket. All in all, very satisfied and hoping to find out soon if the death wobble is cancelled!
