Andy2434
- Andy
- Dec 4, 2017
- Las Vegas/San Francisco
- '19 Billet JLUR, ‘20 Mustang GT/Prem/6MT/PP1
- Occupation
- Retired/Leisure
The Maxtraxs are mounted. I used 4 strut nuts, 4 - 1/4” x 2” lg. SS hex head bolts, 4 - 1/4” SS split washers, 4 - 1/4” x 1-1/4” SS fender washers. I used a 7/16” ratcheting closed end.The only problem I see with that solution is the lack of widened slots at the end of the bars. You might have to completely disconnect the cross rail at the end to feed the nuts in and then button everything back up. Slotted ends would be a nice add by EVO to make this system more functional.
Once I had all the pieces together, it took all of 15 minutes to install the first time. When the boards are not mounted, I will simply slide the strut nuts out the ends of the channels. If a strut nut is not caught and drops down on to the roof, simply use a long length of insulated wire to fish it out.
ETA: I snipped off the blue plastic pieces prior to using. The bare strut nut easily drops into the roof rack slot from the top.
