WranglerMan
- Will
- May 8, 2018
- Katy Texas
- 2018 Wrangler JLU Sahara
- Occupation
- Gas Pipeliner
- Vehicle Showcase
- 1
As I contiune to research the duel battery system on the JL I am curious how many of you are using programmers like the Tazer and how many are not running one.
I have read that a lot of you are seeing 14+ all the time and ppl like me see it float from 12.8 to 14+ and some are running programmers and some are not so I trying to get an idea on voltages.
I have been told several times by an FCA tech that swinging voltages are very normal and seeing a constant 14+ is not but those that are seeing the 14+ don’t seem to have any issues and some are using a programmer and some are not so that’s why I thought a poll would give us all a better idea.
From my understanding and research the JL utilizes a sort of smart charging system and if the batteries are low the alternator will throw a higher charge to the batteries and this is monitored thru the IBS and it only allows the alterantor to charge what is needed so if the battery is only slightly low it will trickle charge towards the battery and the closer to being fully charged the less charge it will send and of course the lower the batteries are the more of a charge is sent.
In my case the starting EVIC displayed voltage is around 13.0-13.5 and after about 30-45 mins of driving it drops to 12.7-12.9 and pretty much stays there while running down the road or idle without allowing ESS to kick in which case it displays the actual ESS battery voltage, the only time I see my EVIC voltage go over 14 is on deceleration or braking and again I was advised that this is how it’s supposed to be so that got me thinking on why a lot of you are seeing 14+ all the time and have no issues
The reasoning by design is if the battery is charged just to the minimum and a minimum voltage is sent via the alternator this will increase battery life and the voltage ramping up to a higher voltage during slow downs put less load on the engine and is supposed to help performance and mileage.
