What exactly have you done? Sorry to bump up this thread again. How happy are you with the current setup after all these months?works ok on 2.2 but took a while to set
Very happy with 1.5 inch lift and 34'' tyres.What exactly have you done? Sorry to bump up this thread again. How happy are you with the current setup after all these months?
What kind of lift did you add? Is it a spring spacer or a full kit? Cheers!Very happy with 1.5 inch lift and 34'' tyres.
cost effective way to improve the off road capabilities, add aggressive look and minimise pressure on durability of original factory set up
air pressure - you just need to deflitae slowly and pinfully each wheel. will not work in cold weather though. it will changew to red and will give you a warning once cold wether hits.
this one:What kind of lift did you add? Is it a spring spacer or a full kit? Cheers!
Clear, thanks. I am hesitant to go for this kind of lift because the geometry is not aligned anymore. But I assume you just ignore it Enjoy your toy!
Hi Alexey, are you still happy with Teraflex lift after all this time? Would you still recommend it? I am considering it for my JL Unlimited Rubicon to improve the look and fit bigger tires than standard European 32” BFG MT ones. Still hesitating between using 285/70/17 tires BGF AT KO2 or Yokohama Geolandar G015 285/75/17 ones Thanks, RobertUpdate.
got 34" inch BFG 285/75/17 on stock wheels with 1.5" Teraflex lift kit. Actual Measurement is 32.8" at 2.3 bar.
also have US version plastic bumper installed.
Looking ok, but I think I would prefer 35" tyres. However this would require investment into new set of wheels. Maybe next year.
hi,Hi Alexey, are you still happy with Teraflex lift after all this time? Would you still recommend it? I am considering it for my JL Unlimited Rubicon to improve the look and fit bigger tires than standard European 32” BFG MT ones. Still hesitating between using 285/70/17 tires BGF AT KO2 or Yokohama Geolandar G015 285/75/17 ones Thanks, Robert
Thanks Alexey!hi,
a bit late to reply but yes - very happy with my set up.
i am still convinced i have the perfect balance between having a great look + better clearance and durability of the suspention.
ps. I can see you went with 34'' . i am sure it will not dissapoint.
