Your first issue would be getting the tail lamps. NoEuro Mopar website to order.Looking at doing this myself. I believe the part numbers are as follows. If anyone can confirm that would be great. Would it be possible with the Tazer JL to program these to function properly with the brake on the top lamp and the amber turn signal on the lower lamp?
68436710AB
68436711AB
I can confirm the 11AB (which is left), as I pulled it out a week ago - can check the right one as well, as it doesn't take much.Looking at doing this myself. I believe the part numbers are as follows. If anyone can confirm that would be great. Would it be possible with the Tazer JL to program these to function properly with the brake on the top lamp and the amber turn signal on the lower lamp?
68436710AB
68436711AB
Just pulled the right one out - the numbers you have are hereby confirmed to be correct:Looking at doing this myself. I believe the part numbers are as follows. If anyone can confirm that would be great.
68436710AB
68436711AB
That is correct. I was looking for the LED versions pictured on the left in your photo. I come from the VW/Audi world so I am used to the coding changes required for lighting adaptations I just do not know the pin out of the Euro spec LED tails versus the US spec. Been looking online for information without much luck. Not sure if anyone in the US has tried this swap yet.Just pulled the right one out - the numbers you have are hereby confirmed to be correct:
68436710AB = Right side
68436711AB = Left side
Note, these are provided of room for the blind spot sensors, visible by the little bulge on the outer sides, but don't have them.
Excellent! I will pull my US spec LED tails out and compare. Thanks!Might get you started - are the wiring colors similar to the US ones, or do you need help on that?
Got these at hand, as I'm on a taillight project myself
