Estimated time to install Mopar lift kit
JeepEagle1
Greg
Wilmington, DE
2019 JLU Rubicon Punk'n Metallic
Purchased my JLUR, 3.6L, automatic, yesterday and the dealer is installing a Mopar 2' lift kit. What is the estimated hours to install this lift?
Spank
A competent mechanic with a vehicle lift and air tools should able to knock it out in less than two hours. I did mine in my garage with hand tools and it took just over four hours, but a good part of that was having trouble getting the damn control arm bolts loose. Man, those were a bitch.
It's an incredibly simple and easy lift to install.
JeepEagle1
JeepEagle1
Greg
Wilmington, DE
Thanks. The dealer salesman thought it would take 16 hours to install. I'm like "What?" That can't be.
NCSUSTATS
Charlotte NC
Wrangler JLUR
Yeah, my Toyota dealer quoted me 5hrs labor for valve cover gaskets too... :giggle:
Spank
Unfortunately, no Jeep dealership is going to give you a remotely good deal on installing that lift.
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
I charge 3-4 hours for the install, but I loosen and torque all the bolts when the Jeep is settled on the ground. That last part alone takes almost an hour crawling around on the ground with the creeper.
The time also includes putting the Jeep on the lift, test driving and centering the steering wheel.
I could easily do it in two hours if I rushed it and skipped some of those steps, but I like to take my time on suspension installs bc one loose bolt can have serious consequences(especially if a control arm bolt falls off or you forget to torque the wheels and one falls off.)
Just my two cents...
LABLUE
Craig
MI
2018 JLU, 2019 Ram 1500 North edition
CDJR Master Tech
I believe Mopar estimates 2.5 hours for labor to install the lift. I know it's easier than the JK mopar lift.
Swanny297
NELA
2018 JL
And you are still letting them install it? Like TTE said 4hrs top, hope you don’t get stuck with a 16hr labor bill from the dealer.
