- Oct 12, 2016
- Westchester, NY
- JLU Sahara
- Banned
I'd like to offer the problem and solution; you the diagnosis. Thanks.
Problem (and I use the term loosely)
ESS won't engage. Rule out all the obvious reasons. ESS disable button not pressed, no CANbus technology turning it off, and engine is warm. It use to engage.
Light errands driver--admittingly little highway to charge batteries. Dual dash cam runs 24X7 but will cut out if battery drops below 12.X volts.
Solution
Trickle charge the rig.
Diagnosis Guess
Replace ESS battery?
Replace main battery?
Don't expect ESS to engage without trickle charging if a light use driver, with a dash cam on when then rig isn't no less?
Something else?
I have an appointment with the dealer in a week.
Thanks.
P.S. I would find it ironic to spend money on electric to charge the rig, to engage ESS, to save on gasoline.
Dual battery system, with two batteries, North of $1K and I'm not a camper/overlander: thanks but no thanks.
Solution
Diagnosis Guess
Something else?
Thanks.
