ESS on a diesel!?
imjester77
Frank
2020 JLU Eco Diesel; 2014 JKU Sahara
I’m not sure, and could be wrong, buuuttttt, starting the motor and shutting off the motor of a diesel is bad right? I mean, I know that the gas version has only the wear on small components like, rings, and valves, and starter. So how about a diesel that has high compression, And a turbo (that needs to be cooled by oil)ect. How does that effect the longevity of these motors? Or does it not?
I’m not being sarcastic (and that’s hard for me) but I bought a $56k Jeep, and want to see it last. When my ESS kicks in, man my Jeep hates it! I usually then remember to disable it at that point.
Stormin’ Moorman
Michael
Georgia
19 JLUR, 20 JLUR, 21 JL, 21 GCL, 89 YJ, 04 LJ
Forester
The JL Tazer has a diesel option, so maybe just get that
BearcatMLA
Brandon
Ruston, LA
2020 Jeep 3.0L diesel granite crystal metallic
I am not an engineer or a mechanic so take my opinion for what it's worth... Perhaps I'm old school but I do not want my diesel starting and stopping all of the time. I have owned several diesel engines in the last 15 years and always err on the side of letting them run rather than start/stop constantly. I disabled mine by removing the switch under the hood and am considering a better solution with the Tazer(or similar product) that will also account for the oversized tires, keeping the rear view camera on, etc. I wish that the system had a memory that would allow the user to set the system as a default to what they choose for their vehicle to do rather than mandating it to always reset when the Jeep is turned off.
Plongson
Paul
So. Utah
2020 Wrangler Rubicon JL Diesel, 1984 Jeep Cherokee XJ
Retired engineer and business owner. Vibration analyst, reliability specialist.
?? Is that one of the buttons under the hood are for?? What's the other one?
They had (have) me puzzled...
Ruby Clatterbox
SW FL
2021 2 dr. Willy's
It's beyond me why it's even on the diesel. Trying to squeeze more fuel economy at the price of starters or short run problems?? Get a Tazer and forget about it.
Andy-jr.
Andy
Maryland
2012 White JKU, 2012 Black JK 2018 White Grand Cherokee, 2001 TJ, 2020 JLUR EcoDiesel
Get the JL Tazer and set it up and you will never have to worry about pushing that button again. I've had one on mine since March. The Tazer remembers your setting that was last used, so if ESS is turned off when the Jeep is turned off then it will start like that the next time.
Capricorn
Las Vegas, NV
2024 JL Willys XR V6
Network Architect & Engineer
I have no problem with ESS. On street driving when the turbo is not too hot, I prefer ESS. But I do turn ESS off when I drive on the highway or under load and come to an exit where I have to stop at a light. Stop/Start should have been programmed not to be active when the turbo is hot.
rickinAZ
Rick
Phoenix
2021 Rubicon EcoDiesel (11th Jeep)
Be forewarned, if you disable the ESS, your fuel economy will suffer by .1%. Don't blame FCA when you're spending more at the pump. :)
Me? I threw caution to the wind and bought a Tazer.
Capricorn
Las Vegas, NV
If I remember correctly, the other one is the "hood open" sensor.
imjester77
imjester77
Frank
Already Have my Tazer on order. But the whole idea behind a Diesel having the ESS just seemed straight Idiotic to me. personally I think that whole system should be thrown out with all the other forms of Cali-Nazi-ism like DEF and high temp running diesels.
Ruby Clatterbox
SW FL
2021 2 dr. Willy's
Preach it!
brewski
Jack
Washington
JLUR-diesel
