Engineering Explained: What is the best 4WD system? (video)
BillyHW
BillyHW
CAN
Maybe this is a stupid question, but it's been a long time since I was in physics class: In the first scenario, if the engine is producing 500 lbs*ft and only a total of 40 lbs*ft is getting put to the ground by the wheels, where does all the extra torque go?
Chocolate Thunder
Jeremy
The slipping wheel limits all the other wheels to putting down an equal amount of torque.
sigsegv
Adam
Seattle, WA
I don't believe the engine is producing 500 lb-ft of torque in the scenario where wheels are slipping and you have open diffs. Similar to what's going on when you rev the engine in neutral. The engine would over-rev if given enough fuel/air mixture to produce peak power when it has no load.
