Engineer hp and torque graphs and tires
wanderer
Ralph
Carlsbad CA
Engineering Geologist
hey everyone, I’m looking for an engine torque and horsepower chart that plots RPMs versus horsepower and torque when I’m trying to figure out is if I switch from 35 inch tires to 37 inch tires and I have a 456 gear ratio what will be the change in my RPMs on the larger tire at a 70 miles an hour in eighth gear
Assuming I can still pull eighth
I know they used to have these charts out for the JK 3.8 motor but I haven’t seen an accurate one for the newest version of the 3.6 my Jeep for what it’s worth is a 2024 Rubicon X
The second part of this inquiry is I’m on BFG 35 which I know or a small 35. I’m thinking I wanna try something different. I still want basically an all-terrain. I’d like it to be as quiet as reasonable but still a good off-road tire for most conditions I know there’s compromises I’ve been thinking about going with Thompson maybe COOPER or Nittos or toyos maybe even Patagonia
jadmt
jeff
montana
2nd 392
Ca
What would be a good RPM to shoot for at 70mph
Jeep Wrangler JL Engineer hp and torque graphs and tires BD7F306C-BB15-46D6-B3A3-C5F6D291A88F
1,943 RPM 😁 4.56’s -37’s at 65 is 1804 RPM divide by 13 X 14 = 1943 at 70. 36’s are 1854 at 65- 1997 at 70. If the chart in the gears/axles section is for true size and you have BFG’s, likely about split the difference. 🙄
wanderer
wanderer
Ralph
Carlsbad CA
So
What would be the hp and torque loss at a150 rpm less ?
2nd 392
Ca
So
Does this help ?
Jeep Wrangler JL Engineer hp and torque graphs and tires F1101DA0-B15C-47C8-B1E1-F3D36B02D5EB
I would want at least 4.88 to bring the RPM up to 2079 at 70, 5.13’s wouldn’t hurt at 2186 RPM, well into the torque curve. …. Of course, chart numbers and tires vary but ballpark.
at the wheel dyno graph IIRC, I can’t be more specific, but that engine likes to rev.
Edit- 37’s are all heavy AF except for KO2’s, the only C I’m aware of.
Twisted10
Brandon
Western NY
2023 Wrangler 392 XR/2022 Ram Cummins
my 392 w/ 4.56's doesnt care about the 38's.. hope that helps...
TrustWonUSA
texas
2024 Jeep Jl
Does this help ?
Jeep Wrangler JL Engineer hp and torque graphs and tires {filename}
I have the 4.88’s with the 315’s in the v6 Auto. Tonight at 62mph I was right on 2K rpm
2nd 392
Ca
The chart shows 2041 at 65, so it’s reasonably close considering tire variance. ie- the Interco 35’s on my PU are true 35’s, no squat. The Toyo C’s on the Jeep are ~34.5 iirc and do squat. I don’t recall the Jeep, but it was still reasonably close to the numbers when I checked after getting 4.56’s/35’s.
azjl#3
North AZ
Impressively steep torque rise brought to you by vanos.
I sort of think your measuring with a micrometer and cutting with a chain saw. Little wind, incline, extra weight, the plan goes out the window
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Define "good". Best mileage at 70? Best acceleration from 70 to 100+? Best engine braking? Best towing? Something else?
Note that "best" can vary by engine and is impacted by transmission gears, diff gears, and tire size. Additionally, things like weight, aerodynamics, altitude, road grade, etc. impact what might be considered "best" in any given situation.
wanderer
wanderer
Ralph
Carlsbad CA
Mainly i was trying to see what the hp and torque values drop to when the toms drop as a result of going to a lsrger tire size so far it looks like the drop in rom is around 150
Now to plot it and see what that means in terms of hp and torque
i ask the owner of shift auto about going to 37! And he said not a problem at all😃
azjl#3
North AZ
I think it is mostly moot as what gear is this happening in, 8;7;6?
the tranny does a real nice job doing what it needs to do to get what you want.
TrustWonUSA
texas
2024 Jeep Jl
Goooood point
