YenBoon
- Ben
- Nov 2, 2020
- Queens, New York
- 2021 JLU 2.0T
Preface: 90% of the time I'm in my Jeep, I turn the ESS off immediately. I have a 2021 JLU Sport S with automatic transmission.
I had just set out to grab some lunch and was about a mile away from my house when I came to a red light. I came to a full stop and heard the engine shut off. When the light was getting ready to turn green, I let my foot off the brake pedal slightly so the engine would turn itself back on. I felt the engine crank back up but as soon I let completely off the brake pedal my engine stalled out. I was in a mild panic so I'm not exactly sure which one lit up but (it was either the "P" or the "D" on the shifter) one of them started blinking. I put the Jeep back into Park and then dropped it back into Drive. I immediately turned off the ESS and continued driving and luckily didn't come across that problem again. Has this happened to others in the past? Is there anything I can check up on to see if it's a hardware issue? Thanks in advance!
- Ben
- Ben
