Chupacabra
- John
- Oct 13, 2020
- Greenville, SC
- 2021 JLU
I have searched all afternoon and can't find an answer to this question.
I have a 2021 Sport S without the LED package. I put in Lasfit Switchback dual-color bulbs in the front fenders, and they have been working flawlessly for months now. They are white when the lights are on, and amber when turn signal is on.
I tried to use JSCAN to enable them to be DRLs with limited success. I'm using the ECRI SGW bypass module and the OBDLink MX+ ODBII module.I set the following options:
However, with in a few seconds I started getting all kinds of BULB OUT and TURN SIGNAL OUT warnings on the dash. This has never happened with these bulbs until I enabled DRLs. After chatting with JSCAN, I also then tried enabling the following individually and together, and it made no difference still got continuous warnings about bulbs being out.
One final annoyance is that I can set ONE option and hit GO, and it seems to take. If I try to do anything else I get this error:
Then I have to disconnect JSCAN and start all over to make one more change, and repeat. Is this happening to everyone else too? It's quite annoying,
Thanks!
- Daytime Running Lamps Present - ACTIVE
- DRL configuration - CANADA DRL
- DRL Customer Setting On/Off - ACTIVE (made no diff, did not show as option on radio)
- DRL Lamp Location - Turn Signal DRL
- LED Light Settings / LED Front Turn Lamps Present - ON
- LED Light Settings / LED Front Park/Marker lamps Present - ON
- Checked the voltage setting, it's 13.2 or something like that for these positions. I thought maybe since they seemed to dim once I took the parking brake off that they were dropping to 7.x and causing the outage message but doesn't seem to be the case.
Thanks!
