Emergency, resolved
Bzinsky
Usa
2022 rubicon 4xe
I’m stuck, tetering.
My diffs won’t lock, I’ve locked them multiple within last 3 hours.
front right tire in the air. Tried nuetral in the trans, nuetral/4lo in the transfer case
‘22 4xe rubicon
Bzinsky
Usa
2022 rubicon 4xe
Have you tried powering down for 5+ minutes? The electronics don’t reset automatically when you shut down. They maintain some memory for a while.
Trying now, thank god i have cell
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
Manual or auto?
Are you alone?
I’ve had good luck sticking it in 1st gear 4 low and getting out to jump on the bumper. Gotten out of high centered situations a couple times by doing this. May require you to buckle the seatbelt in order to avoid auto park if your in an auto (I don’t remember if this is disabled in low range, I’ve only done it in standard transmissions in my last JL and my old YJ)
kbp810
Michigan
2021 JLU
Stack logs or rocks, if those aren’t available, use your spare tire. Search for a local jeep group, or ideally, a local jeep recovery group. Or let us know where you’re at and I’m sure someone here will know someone in that general area.
Allmoparparts.com
