Electrical/Tech help needed powering e-lockers
ChattVol
Chattanooga, TN
JLU 6 Speed, 2016 Odyssey, 2014 Accord
I posted this in general thread, but also thought this would be a good spot. I'm about to swap takeoff jlur axles into a jlus and need help with powering the e-lockers to a switch near the dash running seperate from the main system. The jlur e-lockers were apparently made by a Japanese company and have a 4 wire system instead of 2 and looks like this(courtesy of @TTEChris)
I was thinking of using the linked Mopar jlur locker harness below that claims to allow your Wrangler JL's front or rear locking axle to be powered. You provide power and ground with your switch.
https://www.moparonlineperformance.com/product-p/77072413.htm
How would this work running seperate from main system? Any recommendations/advice is greatly appreciated.
rustyshakelford
Rock Sponsor (Level 1)
Brett
Navasota, TX
2019 JLUR-8 speed 2020 F-350
You’d run your wire to the switch. There would be a power going to the switch also. When you activate the switch, it’ll send power to the locker engaging it. That guy that is installing your axles should be able to do this in 15mins. Hardest part is deciding on the switches or method to power will be the hardest part of the project.
Brett
ChattVol
ChattVol
Chattanooga, TN
  • Thread starter
  • Thread Starter
  • #3
Brett
I was thinking of using these aux switches
https://www.allmoparparts.com/sku-y...1WAj0EfaJcI39jCAo4XTIDJQPzKvSCwUaAkmxEALw_wcB
Dwayne Lane's Chrysler Jeep Dodge
