- Mike
- Mar 5, 2020
- Michigan wishing I was on a trail...
- 2022 JLR
- Banned
Yes. I ordered 1 yesterday.Is this a Tazer-like product?
It can be entered manually or use the auto calibrate option.Sounds like they have some sort of automatic speedo calibration for tire size?
So, how's it working out? I have a Superchips FlashCal but with all the postings on the forum regarding side effects of using it I'm thinking of going with the ECRI module instead.I mainly purchased this for tire size calibration when I do move up in size. It is at a reasonable cost and comes with the security gateway bypass module as well.
Works great. You connect it per the instructions, make your changes and disconnect once completed. I used it to change the tire size when I went to 35’s as well and changed when the low tire pressure warning would kick in.So, how's it working out? I have a Superchips FlashCal but with all the postings on the forum regarding side effects of using it I'm thinking of going with the ECRI module instead.
In stead of buying this offfering buy the ECRI Security Bypass Module for $24.99, an inexpensive OBDll Bluetooth Scanner and pay JSCAN, $25+- to register your JL's, VIN#.So, how's it working out? I have a Superchips FlashCal but with all the postings on the forum regarding side effects of using it I'm thinking of going with the ECRI module instead.
That’s where this comes in: https://www.zautomotive.com/product/z_sgw_ext/I love this thing. From setting up led turn signals to changing tire size which adjust your mpg and speed. It’s like driving a stock vehicle. I just leave mine plugged in just in case. Plus the connector is kind of a pita to get in and out.
