Rhinebeck01
- May 9, 2018
- Multiple places..
- '18 JL Rubi, '22 Prevost M H3-45,'01 Harley FatBoy
@SargeoverlandI love this thing. From setting up led turn signals to changing tire size which adjust your mpg and speed. It’s like driving a stock vehicle. I just leave mine plugged in just in case. Plus the connector is kind of a pita to get in and out.
With the JL/JT, you are aok leaving the ECRI Security Gateway Bypass Module plugged in all the time but you should not leave then ECRI Vehicle Calibration Device, itself plugged into the OBDll port all the time...
If you leave that ECRI Vehicle Calibration Device plugged in all the time and there is a good risk that the unit plugged into the OBDll port will awaken UConnect, willy nilly and kill your battery(s). So, use the ECRI Vehicle Calibration Device and then unplug it....
Yes, you can leave the ECRI Security Gateway Bypass Module plugged in all the time... BUT, you must remove it before a dealer visit.... the dealership WiTechll cannot work with the vehicle if the 2 cables are not connected back to the security gateway.
