MIke Honcho
- John
- Apr 6, 2021
- Canton, GA
- 2019 Sahara 2.0T
I found them on eBay. I think I paid $100 for the 4 springs and $200 for the shocks.
I have these shocks and springs that I just bought from a 2021 JLUR diesel owner (See photos). I'm using the shocks but I'm not going to use the springs. For my Sahara, I have ordered these Rubicon springs…Where can I get a set of these springs if I can't find takeoffs?
so i just need the springs, shocks, and mopar lcas? I have the sway bar end links. Did you do alignment after the jeep? I like the way the jeep looks on the last pic.Got my Rubi Diesel springs installed today. I’m super happy with the outcome.
Second pic shows the progression.
Stock -> 34s -> 34s plus Rubi springs
If you find a set that includes the end links that's a plus since they are a wear item, and can get snapped when put in a tough spot. No alignment is needed since it doesn't involve steering components, if for some reason your steering wheel is off center you can easily adjust it if & when (youtube has some clips on that).so i just need the springs, shocks, and mopar lcas? I have the sway bar end links. Did you do alignment after the jeep? I like the way the jeep looks on the last pic.
You are the best for people that are seeking informationIf you find a set that includes the end links that's a plus since they are a wear item, and can get snapped when put in a tough spot. No alignment is needed since it doesn't involve steering components, if for some reason your steering wheel is off center you can easily adjust it if & when (youtube has some clips on that).
Dunno about that, but thanks for the kind words, I try to help when I can, but have gotten much more help than I've given around hereYou are the best for people that are seeking information
What shocks are those? Gladiator shocks?I just finished doing the swap on my 2019 Sahara 2.0T.
Original fronts:
3659AC 3660AC
New fronts:
3668AD (both)
Original rears:
3588AA 3589AA
New rears: 3601AA (both)
Caster before: 90.8°
Caster after: 91.8°
(I didn’t change the LCAs)
I gained 2.08 inches on front height and 1.25 inches on rear height. This worked out perfect since I was 0.75 inches higher on rears before and this balanced it out. It’s sitting level now. (Also threw on the Gladiator Fox shocks for giggles.) The ride is sooo much better. It’s hard to explain…before it was kinda jarring going over bumps but now it’s a lot smoother. These are the “after” pics. I didn’t take befores.
About to do this suspension swap myself. I have a JLU Sahara and eco diesel springs, shocks and control arm take offs.Got my Rubi Diesel springs installed today. I’m super happy with the outcome.
AFAIK all stock control arms are the same, check you part #s on the diesel ones, I'd bet they are the same as your Saharas.About to do this suspension swap myself. I have a JLU Sahara and eco diesel springs, shocks and control arm take offs.
Will the eco diesel takeoff control arm suffice? Or is their a longer mopar one I should get?
Thanks for the info. Does anyone have a link to the longer control arms recommended for this upgrade?AFAIK all stock control arms are the same, check you part #s on the diesel ones, I'd bet they are the same as your Saharas.
Here's my install post w/ the part infoThanks for the info. Does anyone have a link to the longer control arms recommended for this upgrade?
Thank you very much. Just ordered the LCAs. I appreciate all the help.Here's my install post w/ the part info
https://www.jlwranglerforums.com/forum/threads/rubicon-suspension-on-2-door-sport.40700/#post-919317
did you install this setup. can you share what the resulting lift was.About to do this suspension swap myself. I have a JLU Sahara and eco diesel springs, shocks and control arm take offs.
