EcoDiesel Engine Chirping Noise
nsa250x
Darrell
San Antonio, TX
2021 Wrangler JLURD, 1976 CJ7
I have a 21 JLURD with 6,200 miles on it. It has the automatic transmission.
I've noticed a chirping noise related to the speed of the engine. It's becomes noticeable just above idle. The sound has become louder and louder over the past several months.
The chirping noise reminds me of the sound my 1976 CJ7 made when the clutch throwout bearing was going bad.
Anybody else have this problem?
imjester77
Frank
2020 JLU Eco Diesel; 2014 JKU Sahara
my dealer told me it was the internal dumping of the blowoff valve. since our system is self contained with no atmospheric dumping, it pushes exhaust pressure back into the system. but it still will make a sound, some are louder than others. So Ive Been Told. personally I call BS, but that is what the service tech told me when I asked a few months back.
Gorilla57
Chandler AZ
2019 JLUR Mojito
That service tech doesn't know anything about a diesel......as a diesel doesn't have a blowoff valve. A blowoff valve is needed on a gas setup, as those have a throttle valve. The blowoff valve releases the boost pressure when the throttle valve slams shut, which causes a rebound pressure wave to hit the compressor side of a turbo.
imjester77
Frank
But will that cause the chirping? Cause I have the same issue too.
Compression-Ignition
Roy
Montana
2020 JLUR 3.0 Diesel, 2020 6.7L F350
Only chirping I've ever been familiar with in association with diesels has to do with the fan belt. My understanding was that upon shutdown, the engine stops so abruptly, that the belt skips/slides over one of the pulleys.
So to me when I read the thread topic it reminded me of that and I wondered if it might be something similar. All that torque being pumped out and then one of the engine components connected by pulley gets to far out of sync RPM wise.
Just a theory....perhaps a bad one....:idea::no::whatsgoingon:
Gorilla57
Chandler AZ
2019 JLUR Mojito
As I said before, you don’t have a throttle valve/plate. Compressor surge can be heard in a diesel, that’s the pressure wave hitting the turbo. But it’s rare and only happens when boost pressure spikes hard and fast. At the same moment, you have to lift off the throttle causing the RPM to drop. The boost pressure has no where to go. This is usually seen with big turbos/high boost diesels.
So, are you hearing this chirping sound when you go WOT and let off the throttle a moment later?
Are you hearing this at shut-down? As state above, that’s the belt slipping, which was very common on older Cummins motors.
nsa250x
nsa250x
Darrell
San Antonio, TX
I hear it when lightly accelerating and cruising up to 30 mph. Above 30-35 mph I don't hear as much due to wind / road / tire noise.
imjester77
Frank
If I blip my throttle off idle i can here it. or if i roll heavily on the throttle under load. its minimal, but noticeable. Sorry for my ignorance on the subject, never owned a Turbo diesel before. Turbo cars, Plenty, but never a diesel or a Turbo diesel at that.
Willys53
mark
commiefornia
1951 Willys CJ3A, all original, 1953 Willys CJ3B with V8 and mods , 2021 JLUR Diesel
No but I have a repeating sound of a siren that happens all the time. Drives me a little crazy to be honest but not enough to take it in.....
I have the same ... distant siren
calemasters
Allen
Springfield, Mo.
2021 Rubicon Unlimited, & Escalade
Retired Mechanical Engineer
Just guessing:
1.) Serpentine drive belt slipping
2.) Drive belt tensioner or pulley bearing
3.) Water pump
hazards280
Midland MI
22' JLUR 392 - Sarge Green
Spot on with the distant siren. I can't tell you how many times I've checked in my rear view while sitting at a stop light. I'm getting to the point where I know to tell myself it's the Jeep, but I still glance just to make sure.
calemasters
Allen
Springfield, Mo.
Is not that the turbo spooling down?
Plongson
Paul
So. Utah
2020 Wrangler Rubicon JL Diesel, 1984 Jeep Cherokee XJ
Retired engineer and business owner. Vibration analyst, reliability specialist.
Sitting stopped and at an idle, mine has a sound like a cat meow-ing under the hood...LOL. My wife says "there's that cat again"...
  • Like
Reactions: DMT
