Ebay Rubi Steel Bumper (not a knock-off) pretty legit!
YFD_322
NY
2017 GC, 2019 GC SRT
FYI, I often see steel OEM bumper take-offs showing up on eBay for around $700. That's if you guys can wait. I usually can't. :)
the only problem is no matter what those takeoffs always have issues. I’d rather spend the extra and get factory fresh and not someone’s used take off
demisx
Dee
Desert Hot Springs, CA
Wrangler JLU Rubicon
Sure, if the budget allows and the wife ain’t balancing books each month - go for it!
calvinf1
Calvin
Northeast
2020 JLU North Edition
What about this skid plate for $112.89? https://www.bamwholesaleparts.com/o...-and-gladiator-jt-skid-plate-steel-68293984ab. I am not sure what the difference is and whether it's going to work with this eBay bumper as well.
Edit: Never mind. Finally found the difference described on https://www.quadratec.com/p/mopar/front-bumper-skid-plate-jl-steel-front-bumper-68293984AB:
This replacement steel plate is an exact replacement that will require the use of the original hardware for installation, If you are installing this plate new and would like a kit with the brackets and installation hardware please see #82215183AB.​
I ordered this plate and the bracket and hardware separately which comes out much cheaper than the kit. Not sure why they upcharge so much for the entire kit together.
ItsNo4RE
NJ
21 JLU Willys/17 Ram 1500
Got links for each?
calvinf1
Calvin
Northeast
Should be able to find this even cheaper. I found a brand new one on ebay for 300 bucks. Went to pick it up the same day. Then spent 200 more for the oem skid plate and hardware. Just waiting on a warm spring day to work on the swap.
YFD_322
NY
what do you guys think of this one?
YFD_322
NY
Just ordered OEM Steel and winch guard from BAM.
Can anyone tell me. Can I use my close out panel from my plastic bumper?
hoag4147
Colleyville, TX
2022 JLUR XR
From Rubi yes
sgtmajor138
Jack
South Central Kentucky
2020 Wrangler Sport S Freedom package
So I finally decide to order one of the non-OEM Rubi front bumpers and find that they are out of stock both on ebay and Amazon for the sellers that have been mentioned. Anyone have another vendor/seller that they would recommend? Or do I try to be patient and wait for one of these to come back in stock?
As always, appreciate the help and support on this forum!!
demisx
Dee
I've ordered mine from "rocket-auto19" but, unfortunately, they are also out of stock. :( Try contacting them on the ETA. They were pretty good communicating with me.
YFD_322
NY
Received my bumper from BAM today. Fog covers scratched. I’m sure they’ll make good.
WhitneyWillys
Sam
JLU Willys
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! 121D8649-1C87-4D11-B678-E220944D5659
Since you are about to embark on the install, it would be very helpful if you weighed the new and the original ones as you go about it. It will be interesting to see if you experience any "sag" as a result of the increased net weight. Thanks.
