BrandonBeach14
the plastic skid plate won’t fit unfortunatelyNot sure- maybe but with some trimming. I bought the jct offroad skid. It looks better than the plastic and is solid steel so should be durable on trail.
Don’t rubicons come with a steel skid plate under the plastic skid plate? I could have sworn mine has both but i could be wrongthe plastic skid plate won’t fit unfortunately
Kinda, they have a smaller skid plate to protect the sway bar disconnect. I did run mine that way with no issues until I put the Mopar steel skid plate on.Don’t rubicons come with a steel skid plate under the plastic skid plate? I could have sworn mine has both but i could be wrong
Hi everyone! This is my 1st post and I actually installed this bumper less than 2 weeks ago. I wanted a stubby steel bumper for my 2018 Granite Rubi that I just bought in early Nov. 2020.
The bumper comes with no instructions, a few hardware bags, and everything else pictured above. The tow hooks didn’t fit my frame, but I was able to use the ones from my plastic bumper. The finish probably isn’t as good as Mopar, but I was able to touch up with VHT Wrinkle Plus and a heat gun to blend in where I scratched it during the install. The included fog lights electrical connection didn’t match the factory connection so I pulled out the led fog lights from my plastic bumper, secured them w/thick cable ties, and covered them in plastic wire loom for good measure. I also didn’t install the winch plate since there were no instructions. But plan on later. Although I’m sure someone on the forum likely will add a link to this post later. I also reused the plastic cover that covers the frame between the jumper and front end. I did order the Mopar steel skid plate and it also fit. I did have to use some of the hardware from the aftermarket bumper as the holes on the bumper aren’t threaded to use the Mopar skid plate bolts. I also ordered 1 1/8” plastic plugs from Amazon to fill the sensor holes.
The customer service from the eBay company was actually very good. The responded to every email question I had that night. They are in China, but have several distributors in the US where the bumpers ship from. UPS actually lost the 1st shipment and they sent a second after the original due date past with no questions.
All in all I was able to save a few hundred $ over the Mopar stubby bumper and I’m happy with how it turned out. Here a few pics...
thank you!Kinda, they have a smaller skid plate to protect the sway bar disconnect. I did run mine that way with no issues until I put the Mopar steel skid plate on.
Do you have a link or a part number for the mopar skid plate?Hi everyone! This is my 1st post and I actually installed this bumper less than 2 weeks ago. I wanted a stubby steel bumper for my 2018 Granite Rubi that I just bought in early Nov. 2020.
https://www.bamwholesaleparts.com/o...or-steel-bumper-only-new-oem-mopar-82215183abDo you have a link or a part number for the mopar skid plate?
Thank youhttps://www.bamwholesaleparts.com/o...or-steel-bumper-only-new-oem-mopar-82215183ab
This was the cheapest I found online...
Congrats on finishing it up. Please post some close-up pics when you have a chance.finallygot around to installing the rear on mine over weekend. FYI it is amuch bigger job than the front and I was not anticipating that at all. The backup sensors seem to work fine, and I used the plastic bezels that came with the bumper with a dab of glue to hold them tightly in place. Turned out great. Downside is the metal is not perfectly straight on the top side so if you look close enough you can see some minor variations.I got more than I paid for on the front bumper, got exactly what I paid for on the rear. Also I couldnt get the leds to light up so those are just unkhooked, then again the stocker did not light up either so eh, no biggie.
