Ebay Rubi Steel Bumper (not a knock-off) pretty legit!
Abnmarine
2020 JLU Willys
I’ve been debating on this bumper for some time now and after reading this post decided to purchase one. I ordered it Monday and was surprised that it arrived today. The box had a few tears but the bumper was wrapped good and didn’t have any damage. I was pretty happy to see this.
I transferred the OEM fog light harness. My LED lights from my Willys wouldn’t work with the brackets but the lights that came with the bumper work just as good.
I chose not to install the winch plate since I now live in Florida and don’t really need one. I weighed my factory bumper at it was 28 lbs. The new bumper without the winch plate and end caps weights 54 lbs.
It easily bolted up and I torqued the nuts. I need to order the steel skid plate, brackets and I’ll get the OEM bump pads.
Overall I’m very happy with the bumper. Thanks to all of you who posted here.
davidafuller
Hartford County, Connecticut
2019 Wrangler JLUS (Granite Crystal)
CPA
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! A616A8EA-FFB4-42A8-8CF2-4C2D869F9861
Since you're one of the most recent posters, I'd love to get your thoughts here. There are a few issues I never really resolved and I'm a bit concerned about them.
1. What did you do with the stock wire harness? I know you said you reused it, but that harness is pretty long and there's really no way to zip tie it or otherwise thread it in a way to keep it "safe."
2. I'm still unsure about this; is there a way to protect the backside of the bumper? At the moment, the backside is open. Did the bumper come with a plate of some sort that was supposed to attach to the back? When it rains, I'm seeing water get on the inside of the back and it's wetting the harness to boot.
3. Is anyone, you included, noticing rust spots? I'm seeing a couple spots here and there (they're tiny, but it's annoying) that appear to be rust already, even though I just installed the bumper not more than a month ago. Any remedies?
Many thanks.
Abnmarine
2020 JLU Willys
There are some holes already in the brackets in the back of the bumper. I used these and also the factory harnesses push in clips. I also used one zip tie near each fog light to secure it.
It is open to the backside. As was my factory fog lights were. I don’t foresee a problem as the connections are water tight.
If this happens to mine I will remove it and just have it powder coated locally. I guess you could just paint it with matte black.
davidafuller
CPA
Okay, that's good to know. I figured they were water-tight but wanted to make sure I wasn't missing something obvious. Appreciate your response. I guess I'll try to reconfigure the harness and find places to zip tie it. Thanks!
CptFloridaMan
Gabriel
Miami
2018 JLU Sport 2.0
Many thanks.
I installed a while ago, but I'll chime in.
The wiring harness I sorta have it all over inside the bumper until I get a winch and a few zip ties. It's kinda just there. Gotta find a solution to hold it.
2. It didn't come with a plate for the rear of the bumper.
3. My bumper front and rear have little rust spots. Thinking about sanding and painting the entire thing a new black soon.
davidafuller
CPA
Okay, so I'm not missing anything glaringly obvious. I need to find a solution as well; thank you both.
If you wind up sanding/repainting, let me know how that process goes. I really hope it doesn't come to that but if it's already rusting, might be something I have to do at some point.
CptFloridaMan
Gabriel
Miami
2018 JLU Sport 2.0
I think the best solution is gonna be to have someone powder coat it. I'm looking around to do that sometime in the spring.
davidafuller
CPA
Ugh. That's gonna cost a pretty penny I bet. But you're probably right.
CptFloridaMan
Gabriel
Miami
2018 JLU Sport 2.0
I definitely wanna do it myself, or rather attempt it on my own first.
Stingray20Idaho
RE
Boise
2020 JLUSX
Tried my hand at the rear bumper today, front bumper next week. I started by stripping and repainting the entire bumper with matte black enamel. I put smoked lens covers on the reflectors. I'm waiting to wire up the reflector brake lights along with some auxiliary backup lights in the sensor holes next week. Did anyone else have problems with the Rubicon spare tire being too tight against the bumper? I wonder if I need to swap my tire carrier since it's not a OEM Rubicon tire carrier?
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! 20200912_165624
Fsttanks
Tony
Palm Springs Ca.
2013 JKU / 2014 JK / 2020 JLUR
PART 1 of install.
Just installed the front “EBay Rubi” bumper and winch plate over the weekend.
Overall an easy install which I made harder by completely stripping the bumper down to its individual parts and building it back up using my factory: LED lights, red tow hooks and crush cans form my old JK bumper.
An observations. The tow hooks that come with this bumper are not the new JL style they are the old JK style and IMO poorly cast in comparison to the factory JK or JL one. I did take a photo of them side by side with a factory JK hook but did include it in the photos below. Because of the poor casting I went ahead and reused my factory JL hooks. Better safe then sorry.
Below are photos of PART 1 of the install
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! A9D9FA3A-6FD6-4938-85E0-6648F5395F53
Tearing the bumper down to base parts
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! 2BED40AB-CAD4-4496-8371-30B0DAE0210D
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! ADC7390A-A28D-46B4-9B5B-58A2472FB25C
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! 0FF0125A-F9DB-4529-887E-6782B991BDA3
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! BB57248C-E23F-4A7C-A1FB-7BA5AEB15EEF
Cutting out crush cans from JK bumper and test fitting them. Note the JK and JL crush cans are identical.
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! 43B7188F-74E5-48FC-B91D-57EBDE461FB1
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! 1BDB5971-0418-4585-912B-45774A83875C
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! 17FA9966-0673-47BB-B6A9-DD29979964DA
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! 3270439C-95BE-4A90-ACC8-C694BB0680FC
Fsttanks
Tony
Palm Springs Ca.
PART 2 of install.
Test fitting of factory JL tow hook and crush can.
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! ECE97795-AF43-4E41-9A54-6742F96A9D3B
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! DD4EAB67-8B33-4EA7-9E90-FF8B336F5BBE
Installing the factory LED fog lights using the included brackets.
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! 9CAE88FA-667E-4BA5-8C41-20722EEDE210
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! C6E9939F-76E8-4A04-8CB8-C452C1C51BFD
Putting it all back together.
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! 13F0FBBC-5107-4712-88AB-398AF78CA6F1
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! AD8D7D7C-DE28-44C2-9538-89D356BFC137
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! E747DBB6-E730-47FF-B8E8-92AE26BAAF25
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! CA32060A-532C-4722-886F-8C1D2D210E78
For those asking how the winch plate installs. The first photos below are of the “L” brackets that mount under the plate. I used the supplied bolts for now but will be replacing them with known quality western made automotive grade 8 bolts when I install my winch. No way I will be trusting the included bolts of unknown quality for winching.
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! A9674542-2F17-40B8-BBAE-5F7DFCD27B15
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! F929E5BC-ED99-4BB1-AE66-3D3FFA9C873D
Top of winch plate vvvvv
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! 24FC4460-E2EE-4C1D-AC89-550D7236726B
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! A6B206C8-E834-41B0-BDDF-50EBE8A4CB96
Fsttanks
Tony
Palm Springs Ca.
PART 3 of install.
This is how it all turned out. Overall weight increase (which including the winch plate) over the stock plastic factory bumper dropped the front end 1/8 inch(~3mm).
I do have the bumper end “wings” but will most likely never use them. I have always liked the stubby Rubicon bumper look.
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! B0C20465-58BC-4548-87EB-6B605F49E648
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! 7868EA60-74B2-4BA6-A66A-65C264E7B6E4
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! 25D8CA1A-423C-465D-95D4-9A48D5423F80
Jeep Wrangler JL Ebay Rubi Steel Bumper (not a knock-off) pretty legit! 9F390E15-A945-4946-837E-08EBB7DC9196
Only thing left at this point was to confirm the correct fog light aim and make any needed adjustments.
Your thoughts?
Abnmarine
2020 JLU Willys
Looks good. Seems that the 2020 Willys LED fog lights are different than the Rubicon fog lights since mine wouldn’t work with the supplied brackets. I ended up using the lights that came with the bumper.
