James57
- James
- Jan 26, 2021
- Vancouver, BC Canada
- Jeep Rubicon
I just came across your comment about using the E Torque batt. for power acc.I am using the 48V e-torque battery to power my compressor and fridge.
I am using a 48V to 24V DC-DC convertor, but same could be done 48V to 12V if you already had 12V accessories. I used a DC to DC by Vicor engineering but there are many good ones that are >90% efficiency.
The higher input voltage means more efficiency so I urge you to run at 24V if you can as you will get longer run-times.
The setup works well, and what is nice with this setup is I don't need to worry about discharging the primary battery. Even after a run down test the JL starts fine, tells you start/stop is disabled while the 48V is re-charged, and as this battery charges at a much higher current you get a very fast recovery when the engine is running.
Let me know if you need any help, but this is not a project for someone not comfortable with electrical systems. The 48V battery is lithium and if you screw up you have a fire on your hands that most fire extinguishers can not put out. This is why Tesla's like to burn to the ground.
What is it that you did to make this work.
I do have experience with electrical systems.
I have a 2021 JLUR
Thanks
J
