AFD
- Oct 13, 2021
- Northeastern US
- 2023 JL Rubicon (2DR/V6)
Agree that the 12V AGM appears to be junk, just from reading everything around here for years.The starter isn't the wear item, it's the 12v battery. The AGM batteries in our vehicles hate charge cycles. They like to stay topped off. If you're constantly bringing it down to 60-65% SoC due to stop/start you're going to have to replace it much sooner than you'd expect. This is why our batteries are known as "junk". If you don't use stop/start and don't let it sit for long periods of time they easily last 5 years.
If you're a stop/start enthusiast you're lucky to get two years out of them. If a vehicle comes in with <10v we replace it. We don't bother testing it as they will recharge and test just fine then be dead 3 days later.
So do you know 100% in the eTorque whether the accessories are pulling from the 48V or the 12V with engine shut off during start/stop?
If everything is drawing from the 12V during that time, then I could see that being a valid negative to using start/stop. I was always under the impression that the 12V is used for nothing other than the initial engine start, therefore making absolutely no difference as to whether or not you use start/stop.
The vehicle is started by the 12V and then the BSG charges the 48V, while the 48V charges and maintains the 12V (with engine on or off, afaik).
Using ESS does seem like unnecessary wear on the engine. Personally, I just manually disable it at every start and only re-enable it if I'm coming to a red light (or construction stop) that I'm expecting to sit idle at for several minutes. I also turn down my radio and turn off the HVAC at that time, just to avoid any unnecessary draw.
