Colorado DYNATRAC REAR AXLE
joelmilehigh
Joel Spicola
Denver, CO
2011 Tahoe
  • Complete Dynatrac JL Pro Rock XD60 Full Float Standard-Cut Rear Axle Assembly
  • Custom Machined Dynatrac JL XD60 Standard-Cut High Ground Clearance Heavy Duty Nodular Iron Full Float Rear Axle Housing,
  • Includes: - 4.0“ Diameter x .25” Thick Wall Lightweight High-Rigidity 4130 Chromoly Tubes and Heat-treated Chromoly Full Float Fixed Spindles
  • Installed - Axle Width 70.0“ - XD60 Heavy Duty 3/16” Thick Fabricated JL Rear Coil Spring Suspension Bracket Assembly Kit with Raised Track Bar Bracket
  • 4.0“ Tube
  • Installed Differential
  • ARB Air Locker
  • D60
  • 4.56+
  • 35 Spline
  • Installed Ring & Pinion
  • D60
  • 4.88 Ratio
  • Standard-cut
  • Installed Ring & Pinion Set-up Kit, Pro 60
  • Rear, Standard Cut Pumpkin, Includes Carrier Bearings, Installed Yoke, D60, 1350, U-Bolt, Installed U-Bolt Kit, 1350 Yoke
  • Included Brake & Wheel Hub Assembly Kit
  • XD60-Std Cut Rear, 2018 JL, Full Float, 8 on 6.5”, J8 Disc Brake Assemblies, Wheel Hub Assemblies, Installed Shaft, Full Float, Rear, 35 Spline, Custom Length, Installed Gear Oil, GL-5 85W-140, Installed to Axle Assemb
For Sale: $5,500
Local Pick Up Available
Shipping Available - Buyer Pays for Shipping Cost
