RenoMD
Disclosure: this is an independent review I received no benefit(s) nor will I by anyone buying this awesome product based on my review.
Bought this lift from @Northridge4x4 whom I’m quickly emptying my savings to I should have bought it a few months ago when they had the gift card promotion.
Like everyone else i was in a dilemma of to lift or not to lift. Well I ran 35’s on my stock JLUR and put 0-1.5” fox ifp shocks on. I was completely content with that setup... see my fox shocks review thread for details. https://www.jlwranglerforums.com/fo...iew-stock-height-can-you-even-flex-bro.30338/
Anyways I lusted to gain better approach breakover and departure angles. I knew I didn’t want to go more than 2.5” but I also didn’t want to break the bank.
I initially bought the rancho 2” lift well Bc of the awesome price and review by way of life. I never installed the rancho. After months of going back and forth reading more threads on this forum and the other jlwrangler forum I passed up the Evo lift (pairing 2.5” plush coils with fox ifp 2-3” shocks) for a sure thing.... after all tony Carvallo was only a lead designer of the JL Wrangler... and why experiment with coil and shock configurations that weren’t tuned for each other... also I watched this hottie install video like 9 times :P
Finally I decided to buy the Dynatrac lift. I installed it myself without a single person helping me. Not even with the rear coils. The 3-4 hr estimate turned into 6 hours. One suggestion I have is do NOT rely on way of life’s install video especially when it comes down to installing the Dynatrac rear sway bar link. Don’t get me wrong he has a lot of useful info He shows using the Dynatrac supplied bolt for the top bolt hole but this is wrong and the paper instructions say that it’s for the bottom. Anyways I accidentally drove it through anyways using an impact wrench... ( also not advised).
Edit (7/21/19): I ended up removing the front track bar at the axle end during the front axle step and the rear track bar at the axle end during the rear axle steps. Just like the way of life video. I tried not removing the track bar Bc the Dynatrac video said it’s not necessary .... well i found it is. Retighten when the vehicle is on the ground. I happened to have the rear lower control arm bolts at the axle end loose Bc i was installing skid plates there. But others have suggested loosening (not removing) the control arm bolts to prevent binding. I personally just shot some silicone lubricant at all the control arm joints and haven’t had issues with noise and binding. Just an FYI in case you get weird squeaking noises to look at the control arm bolts and loosen and retighten with the full weight of the vehicle on the ground so you go back to a neutral position.
How does it ride?
I can promise you that the stock coils with fox shocks rode significantly better (again see my other thread I won’t repeat this info so don’t ask) than the stock rubicon coils and shocks. This Dynatrac lift rides even better than both of those by far...(not an exaggeration). It corners much better than stock coils with the fox ifp shocks. There is much less body roll, it feels firm and planted. It does a great job at absorbing bumps. I didn’t go through washboards yet but it’s definitely better than the stock coils and fox ifp shock combination. Does it fix the wandering?? I never had that bad wandering to begin with. I have both adjustable lower control arms and the mopar lift control arms neither of which I have installed yet. It drives great at 70 mph. I do think it’s less flighty and feels like it is wandering less on the highway; but, it’s not a huge difference like some people say. Like @Chocolate Thunder said there is definitely brake dive still; but, it’s definitely less compared stock coils in my opinion and the fox ifp shock combination.
In terms of lift. I was surprised...I thought this thing was a 3.5” lift after I installed it but it indeed is a 2” lift. Maybe being 5’8” does that to you haha... That being said I did install the teraflex 0.5” front coil spacers Bc I have a 75 lb warn winch and a 60 lb steel bumper. The jeep sits perfectly level. I checked multiple places on the frame etc. and measured as well before and after. The best part is I didn’t need to adjust the toe at all. If you read way of life’s thread about how to do your own alignment on his jlwrangler forum he explains why it is that toe is unchanged after a lift... basically Bc the drag link and tie rod are independent of each other if you don’t adjust the tie rod there’s no way your toe setting would change.... I mean this makes sense that’s the only way to change toe aside from damaging something to induce an altered toe. Either way I still checked and I’m 3/32 toe in after the lift. So basically you don’t need to get an alignment at all unless you have adjustable control arms.
I’ll test the flex soon and post up pics.
Sitting in boxes are steersmarts track bar and tie rod along with a fox steering stabilizer. In all honesty I don’t want to install these until I get 37’s this winter I’m going to keep driving this around as is. Who knows maybe I’ll just sell the steer smarts stuff.
If you are stuck in a dilemma, just buy this lift. It’s totally worth it.
How does it ride?
