loganbsummers
Stock wheels. I could use a center mount brake light, but there is still the issue of the carrier rubbing on the backside of the wheel, and the gap between the wheel mount and the wheel.I didn’t run into that, I am running 18x9 Fuel Wheels and 35x12.50s, everything bolted up just fine, if you can’t fit your brake light on there maybe look at one of the brake light rings? That way you don’t have to worry about the clearance issues? :P
Are you running the stock wheels or aftermarket? The backspacing on my wheels pushed it out enough that I didn’t have any issues.
I'm glad it's working for you but at some point, for me, it seems like there's a better solution than to use a carrier that "should" work without issues and work-arounds, but doesn't.
