Dual Top Group Question - Sahara JL
RichK.MA
Rich
Shirley' MA
2018 JL Sahara Unlimited
I'm a new Wrangler owner, so I'm not sure if this question has already been discussed. I bought the Sahara with the dual top group. I took the hard top off and installed the soft top without any issues. My question is, can I keep the soft top on and reinstall the hard top over it? I know there are a couple of brackets that need to come off first. Wondering if I need to take the whole soft top out though for the colder months. thanks
Kadonny
Malvern Pennsylvania
2018 JLUR Manual Trans Front Spacers, 2010 JKU Wrangler Sport
Physically not sure if the soft top will fit under the hard top, but either way you don't want to leave it on. You have to take off the rear corner brackets anyway so just undo the 4 bolts and take the whole thing off. You'll be much happier plus your soft top will stay newer longer and it's what Jeep recommends.
thecritter
Rusty
East Texas
2018 Crystal Granite JlU Rubicon
No it will not fit. At least on a JLU can't speak for 2 Door you have to remove the vertival door trim piece and two back corner pieces the Hard Top has to use these locations. Also soft top is higher than hard top so will not fit under. You can leave the two metal brackets that the soft top rests/pivots on the roll bar.
RichK.MA
RichK.MA
Rich
Shirley' MA
Thanks for clarifying!
RussJeep1
Westchester, NY
JLU Sahara
I wonder how much of the JLU soft top (and its hardware) would have to be removed--perhaps all as Rusty says above--to fit a hard top.
Door supports, rear corner brackets, back 3 windows: at the very least.
rafaelmcs
Rafael
Toronto, ON
2018 Jeep Wrangler JL Sahara
Yes, you can do it easily however you need to remove the parts attached to the doors so you can connect the Hardtop screws. I've done this a few times....
Extreme Terrain
