Drivers Side Heated Seat Not Working Properly
Newbiehere
Lauren
Kentucky
Jeep Wrangler Sport S
I recently purchased a used 2018 JLU Sport S that has around 50K miles with heated seats and steering wheel. About two weeks after purchase, I noticed that the drivers side heated seat would shut off after about 15 minutes. It will not turn back on until the vehicle has been completely shut off and turned back on. The kicker is, it only happens sometimes, not on every trip. The passenger seat and steering wheel heat are totally fine.
The dealership I purchased from is not a Jeep dealership and I have little faith that they may be able to fix this. When I spoke with the salesman, he said that it was probably shutting off to cool down. I do not believe is the case at all. He also said I could make an appointment with the service department. I’ve owned the vehicle for less than 30 days at this point.
I’m hoping this is something that I can fix on my own, hopefully without tearing the whole seat apart. Any ideas or suggestions on how to proceed?
Wbino
NJ
2021 Wrangler JL H.A. -- 1999 SLK 230
fuse issue?
Newbiehere
Lauren
Kentucky
That was my first thought. I haven’t gotten around to checking yet. If it is a fuse issue, wouldn’t it not work at all? Or, could it be loose and needing adjustment?
fuse issue?
frank-o
Frank
USA!!
392 SOT, JLUR SOT, Prior JLUR Sting, 10thA JKUR
Check that all fuses are seated properly.
BigMaCro
Alaska
www.youtube.com
2021 JLU 4xe Rubicon, 2004 WJ
Carhauler
This happens to me too! Just as you described, it doesn't happen all the time - maybe once a week. When I press the button, it will come on with all three lights, and then shut off after 2 or 3 seconds. Can press it again, but it will shut right back off.
So, I suspect the Body Control Module (BCM) is sensing something abnormal and shutting it off, which is then reset by a power down.
I have installed armorlite flooring, so I guess it's possible that the wire under the seat is loose or damaged. I need to do some digging under there to investigate and secure them.
Multiple places..
@Newbiehere
@BigMaCro
Check your private messages. I just sent you Stellantis Star Case info that details issue and parts needed to fix, etc..
Multiple places..
Newbiehere
Lauren
Kentucky
@Catiajockey
Just pm'd you the Stellantis Star Case info that details the issue and the parts needed to fix, etc..
@Newbiehere
@BigMaCro
Update: It’s magically been working fine for the last week. I don’t expect it to stay that way, but not a concern for now. I very much appreciate the info you shared so I can get it taken care of when the time comes.
aldo98229
Aldo
Bellingham, WA
Market Research
That’s just your Jeep’s way of telling you got a hot ass! :like:
juliearn
Julie
Arizona
2020 JL Rubicon
same thing started happening to me today. Heated seats on 2020 JL Rubicon drivers side come on for 2-3 seconds then go off. Any body know of a fix for it?
BigMaCro
Alaska
www.youtube.com
Carhauler
I think it was resolved by disconnecting the battery - causing the body control module to reset. Everything's been working great this winter thankfully! Dunno why it flipped out for a while...
aggriffi
Alex
Anaheim CA
2020 JL Unlimited Rubicon
@Newbiehere
@BigMaCro
My wife's jeep has been having this problem for a while. Any way you could send me the details of the Stars case as well? It would be much appreciated!
