Driver Side Seat 2 Door
  1. YellowJL
    YellowJL Member
    Vehicle(s):
    2019 JL Sport S
    Oct 19, 2019
    Central Va
    Liked:
    Garage Profiles:
    So I have read about the seat not being able to fold back or latch. I don't think I am having that problem. What I notice is on the driver side, if I fold and slide the seat forward to let someone get in, in order to get it to slide back after they enter I have to pull up on the seat slide bar under the seat. And then I have to guess roughly where I had it positioned before. The passenger seat returns to the position just fine by sliding / pushing the seat without using the slide bar. I "think" the owners manual kind of implies the passenger seat auto returns to position. But I can't understand from a technical reason why it would be designed like that where the passenger seat remembers the position and the driver seat does not. Maybe the drivers seat is about to have issues?
  2. HendersonJL
    HendersonJL Well-Known Member
    First Name:
    Chinh
    Vehicle(s):
    2018 Sting-Gray 2-door JL
    Nov 20, 2018
    Silver Spring, MD
    157
    Liked:
    262
    I don’t remember my drivers side seat did that before it failed to fold back; but I think maybe you should have it checked out. After 25 days at the dealer it seems to fix it and I haven’t had any problem since.
  3. OP
    YellowJL
    YellowJL Member
    Vehicle(s):
    2019 JL Sport S
    Oct 19, 2019
    Central Va
    Liked:
    Garage Profiles:
    Yeah I read the owner manual section again, and it says the front passenger seatS have a track memory which returns its seat to the original position (page 24). So I think it is supposed to be the same for both. I hardly ever have any passengers but I will get it checked out. Just wanted to see if anyone else has the same behavior before the dealer tells me it is supposed to be like that.
  4. SF Pacer
    SF Pacer Member
    First Name:
    Adam
    Vehicle(s):
    2 door JL Sport S
    Aug 19, 2018
    San Francisco
    Liked:
    I think I have the same behavior you do. 2dr on the drivers side if I fold the seat forward using the tip handle it doesn’t go back into the original position (for me, all the way on the back of the track). Because it is all the way back it is easy for me to pull the lever under the seat and reset but if left unchanged it would not be at the back of the track where it started. Hope this makes sense.
Loading...
Share This Page
