funglenn
I bought a soft top second hand and did not get all the gaskets that come with it. Specifically below link shows the driver side door surround. In between the upper and lower piece there is a rubber gasket that sits in between them and comes out abit to cover the joint where it meets the passenger door. THe gasket is almost head height as you look at rear door opening on the rear edge.
I did not get that gasket and unfortunately MOPAR only sells it if you buy the whole door surround! any thoughts on where i can get it?
https://www.quadratec.com/p/mopar/rear-door-surround-wrangler-jl-unlimited/driver-side
thanks
thanks
