Door lock
Jeeptj1
Illinois
2019 sahara unlimited
Ok I’m goin stupid but something happened to my driver door lock. The key fob opens and closes all of them. The passenger door also closes and opens them. Just today the drivers door button doesn’t open them and only locks them. Only had the 2019 sahara jlu a couple of weeks. First time I had the wife in it so I of course blamed her but that didn’t work out real good. Is there something in the dash screen that I could have changed to make only the drivers lock not function. thanks
Hogdreamer
Minnesota
2019 Cherokee, 2021 Sahara Altitude
Both FOB probably will work the same. Not sure about the 2019 Sahara settings but with a 2021 the locks can be changed from unlocking all the doors with one click or just the driver's door.
From the owners manual;
This setting will change how many pushes of the Unlock button on the key fob are needed to unlock all the doors. The “Driver Door” setting will only unlock the driver door on the first push on the Unlock button. The “All Doors” setting will unlock all doors with only one push of the Unlock button.
Not sure which radio you have but you change the setting with Uconnect.
Not sure if you have the owner's manual for your Sahara. If not, you can download a copy from mopar.com.
sf5211
Bronx N.Y.
New 2019 JL
Plumber
Unless they slapped your harness plug in so fast at the factory they messed up the pin in the plug. I had to have my plugs changed from frequently pulling the doors off. Like you my passive locks worked, my fob worked but the manual button on the 2 front doors stopped working.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
If you're talking about the button on the actual exterior door handle, it only locks the door. The sensor on the inner half of the pull handle is what unlocks it.
The operating manual specifically states to not grab the handle when hitting the lock button, because your fingers will also be triggering the sensor to unlock at the same time.
Spearmin
Eric
NY
JLU
Well while your laying there on the couch, I'd sit up and make an appointment with the dealer to get it looked at.
RoadiJeff
St. Louis
2020 2.0T Recon, 2018 3.6L GC High Altitude
That's all the exterior button on the handle is supposed to do. It only locks the door(s), it does not unlock them. You may think that the passenger side button unlocks them but I'd be willing to bet that someone is grabbing the handle when they press the button and that is what is causing it to unlock.
It is all explained in your owner's manual in the "Getting To Know Your Vehicle" section. ;)
Maverick909
Inland Empire
www.instagram.com
i have the same issue but i know its my door harness. just have not had the time to pull the door and check the pins to see which one has moved or bent.
Jeeptj1
Illinois
Guess I didn’t specify. It’s not the exterior door it’s the lock unlock button On the drivers door inside.
Jeeptj1
Illinois
Thanks. Call to the dealer today!
William Korkshire
William
US
Toyota Camry LE Hybrid
What did the dealer say? Let me guess, he charged you an exceeding price saying that the door issues aren't their faults. This is an old story with all dealers around the globe blaming the users for their mistakes.
After several fights with my dealer, I completely gave up on their service. Now, I call locksmiths sw9 for all door issues or go to the nearby mechanic garage.
