Door hinge rock chips
Status
Not open for further replies.
R 3
louisburg, KS
www.r3offroad.com
2018 jlu rubicon 2008 jku 2006 lj
2000 miles on a jlu rubi and about 3 miles of that has been gravel road.
Here is what they look like now.
Has any one else started to see this issue with there jl
Matt,
Redleg22
South Eastern PA
I have had this happen with every Wrangler I have ever owned. Mine was never that bad at only 2000 miles though.
Revelation17
Pete
Minnesota
'00 Corvette; '19 JLRU (Manual, Firecracker red)
slave for "the man"
I assume you have the stock KO2s?
FatBoy01
NY
2014 Wrangler Sahara; 2001 Harley FatBoy; 2018 Wrangler Rubicon JL (Ordered)
Retired @ 55
I do not have my JL yet. I plan on placing small pieces of clear, 3M or Xpel protective vinyl on the leading edge/front side the door hinges. Will do this on day one of ownership.
Skippy
Aaron
Minnesota
2018 JLUR, 1996 Ford Bronco 351W
I had the issue with my 2013 JKUR but no where near that bad. My GF lives on a dirt road and I had aftermarket wheels. I wonder if they have skimped on the paint for this year. I would be bummed and Im sorry yours looks that bad. I purchased some clear 8mil adhesive to put on mine. Looks like I better do it sooner rather than later.
R 3
R 3
louisburg, KS
www.r3offroad.com
  • Thread starter
  • Thread Starter
  • #6
Yes the jeep is 100% stock. the reason i posted this was to see if it is a defect in paint? possibly a adhesion issue? I have a 08 jk and also 06 lj and neither of them have a single rock chip and have been all around the country and neither are stock.
FatBoy01
NY
Retired @ 55
Yes, either get it on there right away or get a new GF that lives on a paved road ! ;)
FatBoy01
NY
Retired @ 55
Not, not a factory paint issue/shortcoming. You would be wise to get OEM touchup paint and touch-up asap. Then apply 3M or Xpel film.
Skippy
Aaron
Minnesota
This is the stuff I ended up ordering for mine. I am also going to put it on the door sills as my dog seems to have a hard time jumping in to the back and her claws hit paint all the time casuing light scuffing. Plus it gives me enough to do the underside of my mountain bikes too
FatBoy01
NY
Retired @ 55
Yup, your choice of 4" wide was a good choice. Be sure to clean area well with rubbing alcohol. Don't just use cutesy little alcohol wipe, buy the big boy size alcohol bottle at the drugstore for $1.45+. After applying film wax the whole area. Wax that area each time you wax the vehicle.
Skippy
Aaron
Minnesota
Yup, your choice of 4" wide was a good choice. Be sure to clean area well with rubbing alcohol. Don't just use cutesy little alcohol wipe, buy the bog boy size alcohol bottle at the drugstore for $1.45+. After applying film wax the whole area. Wax that area each time you wax the vehicle.
I did get the alcohol already. Although I didn't get the large bottle. Maybe I should go get a second one just in case. Thank you for the advise on that. I will take note of the waxing as well. Something so simple could really have a negative affect like that. Thank you
FatBoy01
NY
Retired @ 55
Aaron, (my one Son's name also) Yes, use plenty of alcohol to get wax off of the area you are applying to. Also, you may want to lightly warm up the area after you clean with alcohol. Use a hair dryer. While application area is warm from hair dryer, do the application.
DO, YouTube viewing of how to apply 3M or Xpel film. There is a trick to it.
R 3
R 3
louisburg, KS
www.r3offroad.com
  • Thread starter
  • Thread Starter
  • #15
The heli tape is what I plan on putting on it.
I am going to Cnc cut out of a sheet so they fit good. Should have done it sooner I just have never had this issue.
Status
Bestop
