Anthimus
Hi all,
I'm going to share my experience. I hope others have had better luck, but for me the MOPAR beadlocks have ended in disaster. There are 25 bolts per wheel holding the ring on, and about 70% of them have seized. When trying to remove them, the heads just break off (See photos). The amount of labor it would take or fix my wheels would be more than buying a whole new set. My new set (KMC Machete Crawl) is coming to around $3000 making this a rather expensive avoidable mistake.
I opened a case with Stellantis, and the dealer who looked at the problem (not the dealer who installed them) said in no unambiguous terms that they were installed incorrectly by the other Jeep dealer. Likely no anti-seize. The case stayed open for almost 4 weeks while Stellantis, the dealer who diagnosed the problem, and the dealer who installed the beadlocks in the first place when back and forth. While it seemed promising at first and the communication indicated they accepted responsibility, by the time it went up the corporate ladder and came back down they decided it was "Not a problem caused by installation".
No one outside of the Jeep dealer in question ever touched those wheels. So it's either a problem with the product, or a mistake made by the technician who installed it. Either way, they're responsible but they're still not doing anything about it.
I'd recommend to anyone who is thinking about buying and having these installed by a Jeep dealership to not do it. I'd recommend to anyone who already has these, check to make sure they were installed properly before it's too late and they seize up. Better to go to a reputable off-road shop, and even better yet get non-MOPAR beadlocks. If you are thinking (like I did) that buying MOPAR is the 'safe' bet and that you will have the backing of FCA/Stellantis you will find that's not the case.
