Does your jeep do THIS in park?
Upnarms
AZ
2019 JLUR, 2003 TJ X
So I notice when my 2019 JLUR is in park , the a/c compressor turns on cause the air gets real cold. The a/c light is still off and in climate control settings it shows off still. I do not have it set to auto either. Any one else have the ac compressor turning on when in park?
As soon as I shift into drive it goes back to just vent mode. Again, no lights coming on to show the a/c on, but clearly it is.
00Sebby
Knoxville, TN
2020 JLUR
Ex-auto quality engr & mgt. Now just enjoy life.
Yes, my JLUR does it too. My '12 JKUR also did it when in park even though the AC wasn't on. I don't really know why.
JIMBOX
JAMES
FERNLEY NV
2018 HELLAYELLA JLU SAHARA/2016 "STINGER YELLOW" RAM
My 2018 SAHARA JLU, doesn't doit--
My 2018 JLR- doesn't doit
My 2008 JKUR didn't doit--
Must be your "setting"---
W.E.
JIMBO-
sixspeed
Gregory
Arizona
2018 Wrangler Sport S JL
Any updates here? I have the same problem.
Upnarms
Upnarms
AZ
Nope, still does it. Dealer said they couldn't replicate problem. Such garbage! It never DOESNT do it. So it's such a pain to take it in, I just deal with it for now. I also have issues with the temp control not making any difference until I go all the way up or all the way down before the middle temps make a difference. With AC it's ice cold from Lo to about 78 or 80 before it will go less cool. With heat, it's max hot until i reach Low, then it will incrementally go up. A pain. Next time something else goes wrong like another visor breaking (twice mine have broke at the hinge point/mount) ill bring it up again.
One thing I know is it's more apt (the park thing) to happen after engine warm up, so I need to show the service adviser when I arrive. Otherwise on a cold start, I don't think it's happening right away
Bearded_Dragon
FL
2018 Mojito! Rubicon
Mine has does something similar for a second or two when going from drive to park. I figured it was to help keep air conditioning seals and parts healthy. It only seems to do it when I haven't run the A/C for a while. Otherwise I have no issues with heating or cooling.
sixspeed
Gregory
Arizona
I just took my new JLUR in for this problem (the original post). The tech said he had never heard of it before but at least he saw it happening. He had to talk to the “tech assist team”. I keep thinking would the tech dumbness or the problem itself happen with a Lexus?
Upnarms
Upnarms
AZ
Keep me posted if they figure out what causes it and if there is a fix.
kheidolph
Kurt
Woodland Hills, CA
2018 Jeep Wrangler JLU Rubicon
Sorry to revive an old thread, but did anyone ever find a solution/cause? My 2018 JLUR has started doing this recently as well. Any insights would be appreciated. Oh...and my warranty ran out a month ago. Otherwise I would take this in and make the dealer figure it out.
@sixspeed - Did your dealer find the issue?
Upnarms
Upnarms
AZ
Unable to replicate, which is ridiculous since it does it every time
sixspeed
Gregory
Arizona
It was determined by my dealer (and he’s right) that the A/C comes on when the vent fan is 4 or higher but not 1, 2 or 3. They, of course, could not figure it out or fix it. I haven’t bothered with it since. It rarely is in an issue but is a pain when it happens since I like the vent fan at 4. Plus, given some of the horror stories you hear about on this forum, it is a little thing.
Heimkehr
Pennsylvania
2021 Jeep Wrangler Unencumbered
I had a similar issue with the HVAC control panel on my Ridgeline; the culprit was a fan speed control knob with a mind of its own.
The panel was replaced under warranty, and proper operation was restored. Like our JLs, the Honda's consolidated HVAC panel can simply be pried off and unplugged.
kheidolph
Kurt
Woodland Hills, CA
@Upnarms , @sixspeed , and @Heimkehr
Thanks for the quick response. I had a feeling that Jeep would "dodge" the problem and not have a solution. For all we know, it could be a design feature...but I doubt that. I'll do some more testing on my side to see if I can replicate it in other vehicles. I did notice the fan 4 setting, but thought it might have been a fluke. If I learn anything new, I will post it. But sounds like this is going to be a dead issue.
Goods news (as has been pointed out), this is a pretty small issue in the grand scheme of the other problems people are dealing with.
Thanks!
Upnarms
Upnarms
AZ
I'll have to check out the fan speed 4 thing. The most annoying part is my a/c temp stays ice cold unless i go all the way to high temp then back it down. Same with heat, it's blowing fire unless I take it all the way to cold then raise it up. I miss the old temp knob like my TJ. Very finicky climate control. Im in AZ though so most of the summer I want the ac super cold and doesn't budge from that setting
Retrograde
Michael
God's Country, Idaho
2020 JLSS, 1995 Chevy K2500
Arms Dealer
I've been experiencing the same problem this summer as well, but can not verify the fan speed 4 thing, as it is currently 40-some degrees outside. I'll report back when I know something.
....given some of the horror stories you hear about on this forum, it is a little thing.
Agreed-- It is a small thing, but given the sheer volume of "small things" we have to deal with, it certainly does not encourage a feeling of trust.
Hothead Headliners
