Does Your Dealer Top Off your DEF?
xylodan
Henderson, NV
2021 JLURD
Engineer
I thought I had read that the dealer will top off the DEF during an oil change but I can't find it anywhere. Curious if they do this. When I received my Jeep new it was at 75% full but I was planning (and did) a break in oil change and was thinking they'd top it off then but they didn't. Just curious what I should expect.
bryan8379
Bryan
Fort Collins CO
2020 JLUR EcoDiesel
Mine didn't, I didn't ask about it either. Maybe if you had a dealer that was working on HD trucks as well they would but mine is Jeep only.
Wrangler man
Howard
Palm Springs
2020 JLUAD
They don't top off the DEF. The most extra free service I get upon request is a 5 tire rotation imo the Blue DEF "Platinum" formula is superior to the Mopar DEF and it's by far cheaper at your local Lowe's.
xylodan
xylodan
Henderson, NV
2021 JLURD
Engineer
Great to know! Thanks all!
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
No f'ing way I'd let a dealer change my oil. On the petrol they can't seem to fill the right level and on the diesel most don't use the right oil.
gregssstaaa
Greg
San Diego
2020 Jeep Wrangler Unlimited Willys EcoDiesel
Just got my first Jeep Wave oil change and they did not top off the DEF. And they will only do 4 tire rotations. Just stopped off at the local Walmart and bought a 2.5 Gal of BlueDEF for $12 on the way home.
9mmkungfu
United States
2020 JLURD
That's about $4.80/gallon.
If you guys have a truck stop nearby, usually it will be less. The TA Petro near me sells it at the pump for $3.21/gallon.
Trainman
Fort Worth, Texas
2017 Jeep Willys 2dr
I worked for a large GM dealer and if I remember correctly differentials were filled by factory recommended of OZ'S require by what the manufacture recommendation were, not by topping off, unless that was what the recommended were. Since I don't know on this which is correct, I would do what the manufacture recommendation are. I have seen techs put there finger in the hole and if they could touch the fluid level that they thought was correct, it was ok and at the level for safe use.
