Yep mine bounces too. It doesn’t stay super tight when it’s all the way down. Hard to see out the rear view mirror too.Is the softop supposed to "lock down" when it's folded all the way down? I have the cams in the locked position yet I can still lift the softop up several inches. It kind of bounces around when I drive.
Thanks.
It does, but the word “lock” doesn’t really accurately describe it. What most of us do is to use a set of Velcro or other straps around the top once it’s down. I basically will use three straps (one on each end and one in the middle) around the top and the rear window bar. Holds it tight, as low as it can go, and offers plenty of visibility.Is the softop supposed to "lock down" when it's folded all the way down? I have the cams in the locked position yet I can still lift the softop up several inches. It kind of bounces around when I drive.
Thanks.
From what I understand (and there are many threads on this) the loop with the snaps are for rolling up the back window and securing it in an open mode while the top is still up (which had been an option for generations, despite not working well on the JL due to the window “tracks” along the sides.) The Velcro straps that came with the top are for use when the top is in “sunrider” mode.I don’t know if it’s what I’m supposed to do, but my soft top came with an elastic loop that fastens to the soft top from a “button” or snap, maybe? It also came with Velcro straps that don’t quite fit around the top on their own, but I can make a loop with the Velcro and have it looped through the elastic that is snapped to the frame, and then also through the hook that latches in the front.
I’m not doing a good job of describing it, maybe I can take pics later.
Yep I agree!Even though they've resigned it with the lack of sail panels and the added rail system, the soft top springing around like that is by no means a new thing. Every previous generation Wrangler does it in some form, too. I've come to accept that the rear view mirror is largely useless if you've got the top down and a larger than stock spare tire.
I learned a lot after reading this post ... and the rest of the thread. He talks about using 2" x 36" to stop the bouncing, which has been found to cause wea-and-tear to the top over time if not strapped. The velcro straps seem much better the ones provided and not too much $$ on Amazon.Is the softop supposed to "lock down" when it's folded all the way down? I have the cams in the locked position yet I can still lift the softop up several inches. It kind of bounces around when I drive.
Thanks.
