Does Rubicon even use 8th gear??
exlax66
Shannon
s0k4s2
2020 Wrangler Rubicon Recon
I have a 2020 Rubicon Recon, only 2500 km so far. I notice that it is a pretty rare occasion to see the Jeep shift in to 8th gear. I know the tires are slightly larger on the Rubicon but it also has 4.10 gears. I thought that it would shift in to 8th sooner than something that isn't geared as low. At 110 km/h (68 m/h) it is almost always in 7th gear. Is this normal?
dchemphill1
Nebraska
School Administrator
I have had it in 8th gear in 4 Low. I am pretty sure at interstate speeds it is in 8th gear? This system reminds of those old farm trucks that had 4 speed but had a high low trigger. This thing in a sense has 16 gears or speeds. I have been impressed with it.
zrickety
Technician
On the 6 speed manual, I rarely get past 4th gear. 6th is unusable.
BuffaloBill
Bill
WI
2018 Wrangler, 2014 Ram 1500 EcoDiesel 2020 JLUR Ecodiesel
Mine’s in 8th in the low-mid 50’s mph with 35” tires on flat road.
GSLSE21B
Fair oaks
2021 jLURD
I run 8th gear up the grade to loon lake about 85-90
Uhdinator
Maine
2018 JL Sport HT 2.0T Auto, 2003 TJ Rubicon HT
If you have a heavy foot.....like to accelerate quickly........you are training the "adaptive" transmission to shift at higher RPM's than if you drive like a Granny. You may have trained it to think it should not shift until the RPM's are a little higher.
Fonzilla85
Fonz
Ventura County, CA
2018 Jeep Wrangler JL Rubicon Unlimited
Lawman
I’m running 35’s and have the heavy AEV Borah wheels. I’m still seeing 8th gear on the highway and City.
calemasters
Allen
Springfield, Mo.
2021 Rubicon Unlimited, & Escalade
Retired Mechanical Engineer
I have the 3.0 L diesel. If I am above 56 mph at constant speed and if the grade is <6%, I am in 8th, at 1,850 rpm.
jdubya421
Jakob
Greensboro, NC
2020 Rubicon 2-Door MT V6
When my Rubi was stock I was in 6th gear at like 50mph+ never even needed to downshift on the highway, surely the 8speed can do it. With 37s and 4.88 I am in 6th at like 45+
