Does my sport look lifted.
Mrmojo78
Al
2018 Wrangler JL unlimited sport
Crime scene remediation field supervisor
Hey jeepers.
I bought my sport used and I was deciding on a lift kit. But now that I look at my jeep, it looks higher than most sports on the road. I did replace my stock wheels with rubi wheels with ko2 but the height between the top of the tire and fenders look higher than usual. What is the standard height of a stock sport with rubies takeoffs. Too lazy to go under the jeep.or peel back the fender liners. Thanks in advance... see my profile pic with the ko2s
Coletrickle
Cory
Midwest
03 TJ Rubicon, 19 JLU Rubicon, 21 JT Mojave
Build Electricity with Coal
Hey jeepers.
Didn't see any more pics on your profile page, but looking at the small picture on your page it looks like it is not lifted to me.
Mrmojo78
Mrmojo78
Al
Do you have the 33 Ko2?
Mrmojo78
Mrmojo78
Al
itstotalbacon
NE Pa
2018 Jeep JLU Sport S
I would so no as well ... looks stock height minus the little gain with 33s.
Strommen95
New York
2022 GMC Canyon
Doesn’t look lifted. Someone used to JKs rather than a JL would probably think it’s lifted.
Roky
Roky
If you’re able, stop at dealership and measure distance above tire and see how close it is to yours. Also measure the height of the tire to compare to yours. Not an exact science but will give you an idea. You can also look to see if there are any spacers above the front coil isolators if haven’t already.......:)
Luvmejeeps
Western Pa
2018 jlu sport. 2004 TJ
No...but it needs at least a leveling kit/small spacer lift imho.
Adventure.AS
Port Dover ON Canada
2020 JLUR
I put running boards on my Rubicon for the winter. The bottom of the step is 16 1/4" from the ground. The tires are 35 PSI cold. (I can't measure the fender height for you as Rubi fenders are mounted higher.)
Coletrickle
Cory
Midwest
This is my wifes Jeep Willys and it has the takeoff springs from my Rubicon on it, raises front 1 inch and rear 1.5 inches. It also has Rubicon takeoff 285 ko2's. Compared to yours it appears to me that yours is not lifted.
roaniecowpony
Retired Engineer
Doesn't look lifted to me. But if you're gonna lift it, put a reputable kit in it and get a good name brand aftermarket adjustable trackbar to prevent death wobble.
Mrmojo78
Mrmojo78
Al
Is it 1-1 1/2" with rubi springs alone or is that total height with the tires?
