Does anyone know what winches would fit to this plate?
MRH512
Wrangler Rubicon JLU
You should be able to download a PDF of installation instructions for any winch. They should include a diagram that gives you the "mounting pattern" of the winch. Basically, the number of inches between the holes, length and width. You can then compare that to the distance between the holes on the winch plate.
I believe 10"x4.5" is the standard mount pattern.
Jeep Wrangler JL Does anyone know what winches would fit to this plate? 1619015987291
Jeep Wrangler JL Does anyone know what winches would fit to this plate? 1619016120822
dpike
New Jersey
'20 JLUR 3.6
i have a smittybilt x20 on the warn plate, worked fine.
go thru some of the winch install threads tho, i think with the warn plate you need to set a couple of rivnuts into the frame (but only on certain JL models)
the maximus 3 filler plates do a great job cleaning it up.
