Does anyone know if knuckles off of a JT will fit on a JLU Rubicon axle? I think that they are cast and would be stronger than the aluminum knuckles .
Jaon
Jaon
Jason
Tennessee
Wrangler JLU
A couple of things:
Mopar knuckles are drilled and tapped for steering stops and Reid's are not.
Reid's are orange and Mopar's are black.
I bought the Reid's and sold them and installed Mopar's instead.
Are the Mopar knuckles aluminum or cast steel?
CarbonSteel
2023 Ford Bronco Wildtrak
OEM Wrangler are aluminum; OEM Gladiator are steel.
Here are the Mopar numbers you need:
68477358AA - Front Knuckle, Right
68477359AA - Front Knuckle, Left
roaniecowpony
Retired Engineer
I believe they are cast iron like the Reids. But I could be wrong.
Jaon
Jaon
Jason
Tennessee
Wrangler JLU
Thank you. I expected them to be somewhat cheaper than the Reid.
CarbonSteel
If you want steering stops, the price will probably be close to the Mopar's to machine/drill/tap the Reid's.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
The Reid Racing knuckles are made of high strength ductile iron, which is highly resistant to hard impacts and shock loads. Cast iron would easily crack and break apart, but is fine in uses such as boiler sections in a home heating unit.
Headbarcode
LI, New York
The Reids have molded in steering stops that are meant to be ground down to maximize turning radius. I still have to do that to mine, as I have lost just a noticeable amount of tight maneuvering.
CarbonSteel
Fair enough...for me the orange did it LOL
Headbarcode
LI, New York
Yeah, I'm not crazy about the orange myself. But it doesn't offend me enough to have waited to do the install. My powder coater has a 3 month backlog, so I would've been lucky to get my front end redone before the year was out. The orange isn't nearly that bad, and at least they match the rcv boots pretty well. 😆
