Does anybody know the formula for how many cubic feet of air it takes?
av8or
Randall
Oregon
2020 JLUR, 2023 Rivian R1T
FedEx-retired
The rest of the question is ............. to fill a 35/12.5r17 tire from 12 psi to 32 psi? compressor manufacturers talk about cfm and I’m just trying to figure out how that can be figured in time to fill different tires sizes and/or multiple tires.
Obviously I need help in the smarts department, so please be nice.
Left Field
Tim
Western WA
'67 RS-SS Camaro, 2021 JLUR392
Its kind of hard to take CFM directly and figure out how long it takes to fill a tire as the CFM rating drops off as the pressure increases. I recently boutght a VIAIR compressor, it has fill rate specifications that are helpful and could probably be reasonably scaled for comparable compressors:
Jeep Wrangler JL Does anybody know the formula for how many cubic feet of air it takes? Screenshot from 2020-12-11 15-41-36
For example, the ARB High Output 12V compressor puts out 2.34CFM at 29 psi where this model VIAIR (400H) is 1.86CFM@30psi. The 29 & 30 psi rating points are ballpark close enough for comparison, so if this VIAIR model will fill a 35x12.5 tire from 15-30 psi in 165 seconds, then the ARB should be the CFM ratio faster:
1.86 CFM / 2.34 CFM x 165 sec. = 131 seconds = 2 min. 11 sec.
This math should get as close as you can reasonably expect. Even with a given compressor I'd guess the results could vary by 20% or possibly more. The fill rate can change significantly on whether your engine is running or not (12.x volts vs. 13.x volts), the with wiring length & gauge and even the type of air chuck. It will also vary to a lesser extent with air temperature and altitude (which you probably know all about) and will likely be a little slower as the compressor heats up going from tire to tire.
LF
Robertcladner
Robert
Chicago
2019 Jeep JL / 2010 Jeep JK
I have the VIAIR 400P mounted under the hood with about a 6 gallon tank. It works great. I imagine the portable model is just as good.
Jeep Wrangler JL Does anybody know the formula for how many cubic feet of air it takes? 2.VIAIR-400P
Beancooker
Noah
Verde Valley, Arizona
2021 JLUR
General Manager
Do you happen to have pics of where and how you mounted this under the hood? I have a 400p automatic, and was looking at doing the same thing, but the engine bay is packed full.
HungryHound
Rick
TN & FL
1975 CJ-5, 1983 CJ-5, 1998 TJ, 2021 JLURe
I used my 400P for the first time yesterday. Very happy with it and glad I got the automatic feature instead of saving the $50 as I had debated. The case has a side pocket that is perfect for a set of deflators. My only gripe is the pressure gauge which goes way too high for practical tire inflating purposes. I'd rather have a 0 to 50 PSI gauge and have smaller increments than what they include. I think the markings are at 5 PSI so you'll need a digital gauge to get all 4 tires to match closely (I don't have my fancy JLURE yet to beep at me when the tire pressure is exact). I have multiple Jeeps, so portable was the only way I was willing to go.
Beancooker
Noah
2021 JLUR
General Manager
Agreed on the inflator gauge. It’s worthless aside of getting higher than needed to release air to get the exact pressure needed. I bought this and it works really well. I am tempted to replace the Viair gauge with this, on the inflator pistol. I do like having the pressure gauge separate though. That’s the only reason I haven’t swapped them out yet.
I also like this because it’s wicked accurate, and I can read it without cheater glasses.
https://www.amazon.com/gp/product/B0010E1UGI/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
