Do JK rims work on a JL?
Wraif
New Jersey
19 2-door manual Rubicon, 09 JKU
After I rolled my 13 JK, I took the tires and rims off of it. 35”/12.5” R 17 Goodyear MTR’s on black Mickey Thompson Classic III. I put them on my 19 JL 2-door Rubicon. They didn’t center out on the Jeep right away. It wasn’t until the lugs were all the way on till they pulled the rim to center itself on all the lugs. So is this what hub centric is all about ? I feel like the weight of the Jeep is now on the studs and not the hub. Quadratec stated that the rims WILL work with the JL. I’m just checking. Any thoughts ?
jludave
The Isle of Long
IT Manager
Which lug nuts did you use when you mounted the wheels on the JL? The JK wheels will work, but you cannot re-use the JK lugs.
Wraif
Wraif
New Jersey
Jeep Wrangler JL Do JK rims work on a JL? F4615DEB-5231-4BF7-9639-8E6A38ADDEA7
Wraif
Wraif
New Jersey
I didn’t know about the lug nut difference till the day I was supposed to get them changed, so I had to reschedule and order these.
Wraif
Wraif
New Jersey
Here they are on the Jeep
Jeep Wrangler JL Do JK rims work on a JL? D1E60ACC-82B3-4CDA-8A50-1CBBC8F368B5
jludave
The Isle of Long
IT Manager
I'm pretty sure those wheels are NOT hub centric. You likely need a centering ring.
Wraif
Wraif
New Jersey
I’ve never heard of a centering ring. Where can I get 1 or 4 ?
jludave
The Isle of Long
IT Manager
A centering ring does exactly what it sounds like it should do. It centers a non-hub centric or lug centric wheel on the hub. Essentially it eliminates any play between the wheel and hub.
You need to reach out to a tire/wheel shop or wherever you ordered your wheels from and tell them you need a set of centering rings for your specific wheels and vehicle.
Discount Tire is forum sponsor, you can try PMing them.
Pig-Pen
Eastvale, CA
2018 JLU
jabroni
4wheelparts should be able to get them too since they sell a lot of non-hub centric wheels including MTs.
Wraif
Wraif
New Jersey
Thanks, I’ll check them out.
