Do i need to Regear my JL RUBICON with 35 inch tires?
Dc85
Daniele
Saudi Arabia
Rubicon 2018
Guys,
anyone running 35" on a stock Rubicon ? Can they work without re gearing?
Thanks
Daniel
ThirtyOne
Chapel Hill, NC
www.jeepdoodles.com
you should be fine with 35s.
Dc85
Dc85
Daniele
Saudi Arabia
Rubicon 2018
ok guys!
thank you so much!
Maverick909
Inland Empire
www.instagram.com
8speed auto does fine with 35's anyone on them with the 6 speed manual?
Dc85
Dc85
Daniele
Saudi Arabia
Rubicon 2018
well... because i am an idiot... and i am very new...
i realized that the new tires i want to put are actually 285 (BFG A/T) which makes them around 34in
i think i should be ok...
am i ok to put them on with no liFT?
Maverick909
Inland Empire
www.instagram.com
yes your rubicon should handle the 285 with no issue at all
starrs
Galen
Indiana
Ford Ranger
Registered Nurse
You might want to read the sidewall of your current tires. If you put 285s on your wasting your money. You have 285s on it already
SecondTJ
Il
Jeep
285 is the width, not the height. What is the aspect ratio?
285/75/17 would be a ~33.8” tall tire
285/70/17 is the stock tire (~32.7” tall)
ZONA.OVRLND
Phoenix, AZ
www.instagram.com
'21 392 Hemi Wrangler - Follow on IG @ zona.ovrlnd
You're fine without regearing, as others have said/. If oyu move to 37s, that's where the consideration should be.
WIth a bigger than stock tire though, you likely will rub if you are wheeling and getting flexy with the suspension.
HeavyUser
CO
JL
I will this Saturday! No plans on re gearing immediately, will see what is like offroading and go from there.
jessedacri
Jesse
Los Angeles, CA
2019 Bright White 2dr JL Rubicon 3.6
They're going to be very similar if not nearly exact in size to the stock 33"s, you'll be fine. I would go slightly larger if it were me, but seeing that you're in Saudi Arabia I bet you have different terrain than I do over here in California.
