Do I need to regear if I get 34” tires on my 2 door Sport S
erikthedon
2018 JL Wrangler Sport S 2 Door
Stuck between getting 33” tires and 34” tires but I don’t want to have to re-gear...
I have a 2018 JL Sport S auto with a 2.0L turbo engine. If I get 34” tires, do I need to re-gear my Jeep?
aldo98229
Aldo
Bellingham, WA
Market Research
No, you don’t.
I’m running 35 inch tires on my Sahara; it drives about the same. The 8-speed automatic goes a long way to help compensate.
Also, when you recalibrate the speedometer, it adjusts the transmission’s shift points.
Jeep Wrangler JL Do I need to regear if I get 34” tires on my 2 door Sport S E2FC2094-AA11-4901-8108-726BB9371178
blnewt
New Mexico
Just ask @cosine he knows!
The 6spd is a bit tougher to recommend w/ larger tires and the 3:45 gear set. Is there a 295/70/17 tire that you happen to like, would be a good compromise I think.
erikthedon
Excuse my ignorance since I’m a total noob to this, but aren’t the JL autos 8 speed? Could be totally wrong lol
Black Jeep Convertible
NYC
www.amazon.com
'19 JLU Sport S 2.0T eTorque
Amazon Influencer 😂
I have a 2018 JL Sport S manual with a 2.0L turbo engine. If I get 34” tires, do I need to re-gear my Jeep?
No, you get a tazer and program your tires to the new size. https://amzn.to/3k7zq6P
I have 34's on mine too
Jeep Wrangler JL Do I need to regear if I get 34” tires on my 2 door Sport S IMG_1475
  • Like
Reactions: J0E
Packnbeer
Jamie
Davenport, Iowa
2021 Jeep Wrangler Sport S 2-Door
He said he has a manual so that would be a 6 speed but yes, you are correct in that the automatics are 8 speed. I wouldn't worry about running larger tires. I know several people ruinning 33's with manuals and no issues at all and they get way more adventurous with their rigs than I do. You definitely want to get a Tazer to change your tire size. The dealer will charge you damn near the cost of the tazer to adjust it one time. I use the OEM rims and tires for the winter and run my good rims with 33's in summer time so I have to change mine when I change out wheels at season change. The tazer has some sick new features like the 3rd brake light flash and turn cam so its worth every penny
blnewt
New Mexico
[/QUOTE]
That above bold post was your first, said you have a manual???
  • Like
Reactions: J0E
erikthedon
[/QUOTE]
Wow idk how I managed to say I had a manual. LOL. I have an auto
JeepU4IA
Rod
Los Angeles
2014 Dodge Charger R/T, 2018 Jeep Wrangler JLU
I have 35s with a 6 speed manual and 3.45 gears. No problem. The Tazer is a great investment but more necessary with the auto transmission to correct shift points. With a manual transmission, the only benefit in changing tire size is to correct the speedometer.
Notams
San Angelo, TX
2018 Wrangler JLU, 1969 Mustang, 2007 Triumph Speed Triple, 1990 Yamaha FZR 600
I second JEEPU4IA. You won't need to re-gear with 34's and an auto trans. I'm running 34's (BFG KO2's 285/75 R17 on Dirty Life DT2's) with a 6 speed manual Sport S, 3.45 gearing. Kind of wish I went with 35's now, but was afraid of possible performance decrease. The manual trans is less forgiving when it comes to larger wheels and tires than an auto. If I had had an auto I would have gone 35's without hesitation. I'm happy with the results so far though and it still looks good. I haven't noticed a decrease in performance. But I haven't been on any trails yet since I had them installed. Bottom line, you should be good with 34's.
blnewt
New Mexico
[/QUOTE]
Ok, now that it's clear, like the previous replies, I concur, shouldn't be a problem :)
That Tazer addition is a good plan, even the Tazer Lite will get you what you need regarding tire changes.
DadJokes
Daniel
Indiana
www.youtube.com
Sahara
If it was 20 years ago, I’d highly recommend it. Now with a close ratio 8spd auto and really low 1st and second gear, it should be much more forgiving. I’m going to try 34’s myself with the auto, E torque, 2.0T.
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
35’s on my sport s. I don’t see 8th gear as much as stock but I still do see it. Usually anything above 72mph I don’t get 8th. Below that I can consistently get it. Still average 19-20 mpg highway and 16-17 city. No problems wheeling it either. I don’t do anything above a blue rated trail though.
Pig-Pen
Eastvale, CA
2018 JLU
jabroni
same here. 35s on auto trans. jeep runs great.
