Do I need additional skid plates?
dpike
New Jersey
'20 JLUR 3.6
Put on my ASFIR oil pan skid today. I thought things werent lining up right but it all pulled together nicely. 19mm, 18mm, and 13mm is all it takes. Very happy with it, installed in about 35 minutes. I won't need heavy protection so I went with the aluminum.
Jeep Wrangler JL Do I need additional skid plates? 1000014757
Jeep Wrangler JL Do I need additional skid plates? 1000014762
Jeep Wrangler JL Do I need additional skid plates? 1000014760
Eischman
Hortonville, WI
2021 Rubicon Unlimited
Nice thread, unfortunately for me, every time I clicked someone's link for an oil pan skid plate, they did not make one for the diesel. :(
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
L06An_5
NJ
1999 TJ Sahara; 2019 JL Rubicon; 2021 JLU Willys Wheeler
First and best investment were rocksliders for my first jamboree. By the second I installed the ASFIR engine, transmission and 48v battery skidplates for my 21' eTorque. Easy install and great coverage. Nice and light weight.
DKAwildcat
Don
Overland Park, KS
2018 Wrangler JLU Sahara, 2008 Chrysler Crossfire Roadster, & 2015 Acura RDX
?this.
FWIW, I’m still on factory skids, and ran my last rig on factory skids without issue as well. I wouldn’t expect you to have any issues out in the San Juan tails.
I’m planning a trip to the San Juan Mountains in September. I plan to stay on the easy and moderate trails only (Alpine Loop, Yankee Boy Basin, California & Corkscrew Gulches, Ophir & Hurricane Passes, and the easy and moderate portions of Black Bear). Am I good with just the stock skids on my 2018 Sahara JLU (no lift or big tires)?
wibornz
Ted
lansing, Mi.
JL Unlimited Rubicon
You should be good. The most important thing to remember is the expensive stuff is down the middle of the Jeep. Run rocks over before you try and and straddle the rocks. You can always just avoid them too by driving around them if possible.
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
I hate to give a blanket yes, but you'll be fine. Those trails are well within the capability of a stock wrangler.
Ratbert
PNW
Software Engineer
Are there portions of Black Bear that are more than moderate? I'm pretty sure it's simply scary AF for those that aren't fans of heights.
Zandcwhite
Zach
Patterson, ca
2019 jlur
The entire thing can easily be done in 2wd. All the guides over rate the trails in that area for some reason. Even poughkeepsie Gulch only has 1 actual obstacle and it can be bypassed easily.
