DIY: Rear hatch LED light strip
aCeMedic13
Ambrose
San Antonio, Texas
2018 Jeep Wrangler JLU Rubicon
RN/Paramedic
Looks great! I was looking for a red and white color combo as well. Do you have the part number for the extrusion bar you used to mount the led lights?
American Adventurist
West Florida
2018 StingGray JLUR
Thanks, here are the parts and PN’s from superbrightLEDs.com
West Florida
2018 StingGray JLUR
aCeMedic13
Ambrose
San Antonio, Texas
RN/Paramedic
Hey guys, I'm getting everything together to tackle the project this week. I think I'll be wiring it straight to my aux battery in my genesis dual battery kit instead though. I'll also be using a different but similar type of switch.
But my question is, what kind of adhesive did you guys use to mount the light fixture? 3 M 1 inch wide strip?
XJ-99
Patrick
1999 Jeep Cherokee XJ (sold), 2010 Toyota RAV4v6 Limited (sold), 2019 Jeep Wrangler JLU Sport S, Mojito!
I used 1" gorilla double-sided tape. So far no squeaks or rattles and appears to be holding fine.
aCeMedic13
Ambrose
San Antonio, Texas
RN/Paramedic
What gauge wire did you all use?
xj_scuba
Rhode Island
JL
In your photos, the led appears to be the majority of the width. Are you using more than the 1m channel? This is a superb idea that I plan on doing.
Thanks!
The 1m length is perfect. Though be aware, the window curves slightly where the corner mount does not. It still mounts fairly nicely, doesn't bother me at all. Just FYI.
West Florida
2018 StingGray JLUR
This. And be sure that you use actual 3M VHB double sided tape - clean the surfaces with alcohol wipes prior to install and do it in warmer temps (not cold outside). It makes a difference and you want it to stay put on the trail etc. 3M is the way.
Redbaron73
Ronnie
2020 sport s unlimited;2020 Rubicon Unlimited
I have ordered extra parts to add one to the top of the tailgate itself. This could be very useful when going topless, yet still needing some light to access the contents in the back.
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
The LED strip is RGB so all colors are available with a controller. Are you getting red and white based on where power attaches to the strip?
Redbaron73
Ronnie
The RGB+w has 5 conductors
RED -12v
BLUE -12v
GREEN -12v
White -12v
Black +12v
Without a controller, passing -12v to a single color will give just the single color.
The +W have a true White LED SMD chip alternating with the RGB chip
RGB+++W+++RGB+++W+++RGB+++W
By applying ground to both the RED and WHITE you get a very nice effect :)
